Old 09-09-2012, 07:17 PM   #1
kcej
2mny projects 2 lttl time
Default Oil Leak from Where?
I bought an AU ute real cheap on Friday, prepared to replace the engine, but the motor in it runs GREAT.....only thing is, it has a bad oil leak. When running, its a steady stream, not drops, but a stream, and its coming down from somewhere directly above the passenger side engine mount. It actually runs down between the front bolts and the back bolts that hold the engine mount to the block. Can someone tell me what there is directly above this point that would give access to the oil gallery of the engine? I am naturally hoping for a simple fix, but ran out of daylight before I could investigate further.
Anyone have any ideas, please?
kcej is offline   Reply With Quote Multi-Quote with this Post
Old 09-09-2012, 07:19 PM   #2
XRGhia
meh.
XRGhia's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: Contributions in the technical arena.
Default Re: Oil Leak from Where?
I'm thinking the oil pressure switch or sensor is leaking...
Previous - BF XR6T - 325rwkw, 6 Speed Auto, Process West, X-Force and Turbosmart gear
XRGhia is offline   Reply With Quote Multi-Quote with this Post
Old 09-09-2012, 07:20 PM   #3
BHDOGS
im gonna guess oil pressure switch or sender for a nice easy fix.
Old 09-09-2012, 07:20 PM   #4
BHDOGS
haha just beaten
Old 09-09-2012, 07:34 PM   #5
Maka
Au Falcon = Mr Reliable
Maka's Avatar
Hi kcej, oil pressure sender is there, probably the culprit, was on mine. Remove the wire connector, unscrew the old one, replace with new one (bit of thread tape/loctite sealer on the thread will be good) then reinstall wire connector. Cheap & easy fix at around $20-$30 iirc.
cheers,Maka
Old 09-09-2012, 07:51 PM   #6
kcej
AAhhhhhhhhh Thanks guys
Just went down with a torch, took off the air inlet gear, felt around a bit and you are right. Pressure switch is EXACTLY above where the oil is dribbling down.
Today is my lucky day for sure.
Thanks to all who replied.
Old 09-09-2012, 11:53 PM   #7
mik
mik's Avatar
ford forums rock !
