Old 31-08-2012, 11:18 AM   #1
BlakesXR6
Default How do you know if your head gasket has been change by previous owner.
Well I own an ef xr6 , i bought it at 230,000kms , it has now done 253,000 . Just wanting to know is their any way you can tell if your head gasket has been already change by the previous owners. The car runs perfectly *touch wood* never had a problem with except the fuel pump , I treat it like a pig but I always make sure to service it. The ef xr6's are prone to head gasket failure , I'm surprised it hasn't blown yet lol also wondering how many kms did you guys have when your e series xr6's blow a head gasket.
BlakesXR6 is offline   Reply With Quote Multi-Quote with this Post
Old 31-08-2012, 11:53 AM   #2
Cano90
Cano90's Avatar
Default Re: How do you know if your head gasket has been change by previous owner.
Not sure if you can check or not, but my ef xr6 blew a head gasket at 223,000kms but I was extremely rough on it... loved it to bits though.
AU FAIRMONT GHIA undergoing turbo install
AU TURBO MERCEDES POWERED 502hp @ 18psi
Cano90 is offline   Reply With Quote Multi-Quote with this Post
Old 31-08-2012, 12:08 PM   #3
jphanna
jphanna's Avatar
i have driven a few cars with blown head gaskets in my time.
after they have gone and been repaired (top end only)
lumpier idle (few pots with less compression)
less power (see above)
use more juice (see above)
im no machanic so i may get flamed...but i had enough experiecne with blown head gaskets to know they are common traits.
BMW 125I
Kia Seltos
Suzuki SV650
FG XR6 (son)
jphanna is offline   Reply With Quote Multi-Quote with this Post
Old 31-08-2012, 12:13 PM   #4
FOCUSonTHIS
FOCUSonTHIS's Avatar
I bought my EF XR6 with 135,000km on the clock. I thought I would do the right thing and flush my radiator out and I ended up flushing out the Chemiweld right out of the head. The head was cracked in the first cylinder and coolant was going into the spark plug.
So I had to replace the whole Tickford head with a reconditioned one. Also I a tapped into near the cylinder 6 to get more coolant though there as that is where it normally blows.
Just letting everyone knowing my experience with the EF head/head gasket
2015 MK7 VW GOLF GTI
Previous Cars
2002 AUIII XR6
1995 EF Falcon XR6
2003 LR Focus Zetec
1989 KE Laser TX3
Old 31-08-2012, 12:39 PM   #5
J.C.
Eeeerrrrrrr! I'm going to state the obvious answer here.
Ask him/her.
J.C. is offline   Reply With Quote Multi-Quote with this Post
Old 31-08-2012, 12:42 PM   #6
atec77
I really have to question this rumour , having owned a number of fords over the last 40 years and certainly quite a few lqter model I never had a head gsk problem , never, of course that would be a result of maintenance on the cooling system being done . Head gaskets can and usually do last for the life of a motor to rebuild unless neglected which has its own rewards
Old 31-08-2012, 12:44 PM   #7
mik
mik's Avatar
if it`s been done properly you would`nt be able to tell i suspect.
Old 31-08-2012, 01:33 PM   #8
jphanna
jphanna's Avatar
tell that to an EA owner. my dad never loved a car more than his EA. he bought it from new, wouldnt let any body else drive it, unlike the other cars.
whne the head went on that in less than 2 years, the repair guy told him that,
'i get one of these falcons every week'
enough said.
BMW 125I
Kia Seltos
Suzuki SV650
FG XR6 (son)
Old 31-08-2012, 05:22 PM   #9
ea90gl
ea90gl's Avatar
Look for obvious visual signs on the motor like new or newish looking gaskets, blue or black silicone gasket maker particularly around the front black gasket between the head and timing chain cover, bolts with with marked heads ect might give you an idea
ea90gl is offline   Reply With Quote Multi-Quote with this Post
Old 01-09-2012, 03:01 AM   #10
Iggypoppin'
Chasing a FORD project!
Iggypoppin''s Avatar
Wasn't the reason the early E series head gaskets blew because the gasket was paper? This changed with metal head gaskets on the AU? Not sure but I think I read that on here somewhere.
Originally Posted by HSE2
Today we might get beaten at some of our own game. Tomorrow we reinvent it.
Game. Reinvented.
1996 BMW 740iL V8. TV, phone, leather, sunroof, satnav, all as standard. Now with 19" TSW Brooklands, 2 1/2" stainless steel exhaust, plus more coming soon.
Iggypoppin' is offline   Reply With Quote Multi-Quote with this Post
Old 01-09-2012, 02:28 PM   #11
Werd.
nou
My car blew out a rad hose and did a head gasket.. before I bought it.
219k on the clock and you wouldn't know a thing. I dont think there's any way to tell other than service history or physical evidence.
Werd. is offline   Reply With Quote Multi-Quote with this Post
Old 01-09-2012, 06:02 PM   #12
graham7773
In the last 15 years, I have owned 15 E series 6 cylinder Falcons. As I have been on a disability and age pension, I have only ever been able to buy cheapies. And you can tell. Every one of them had or developed blown head gaskets. Some people simply do not learn that you MUST USE corrosion inhibitor in Ford and all other internal combustion engines. The E series do seem to get more than their share of blown head gaskets though. Re has it been changed, as suggested above, ask.
graham7773 is offline   Reply With Quote Multi-Quote with this Post
Old 01-09-2012, 06:53 PM   #13
KIWI-1
True... but if it hasn't I'll bet there will be red Loctite sealant oozing out.
Fords the family have owned:
Model T, Model A, Fordson truck, 105E Anglias, MkI Escorts, MkI Cortinas, MkII Cortina, Zephyr Six, ZC Fairlane, AUII Ute manual, BA XT sedan, Territory TS SZ RWD.
KIWI-1 is offline   Reply With Quote Multi-Quote with this Post
Old 01-09-2012, 07:06 PM   #14
mex351
mex351's Avatar
Who cares??? If it's going good it's going good so no need to worry bro.I have owned our EF for like 17 years??? and I don't agree with the lumpier idle or less comp cos I got the head machined (more comp) and fitted a new rad,water pump and head gasket all at the same time and it was way better.Till age/km's caught up with the bottom end.
Then I did the smart thing and fitted a AU engine and it has been awesome ever since,but not for long thanks to our new FG XR6.
mex351 is offline   Reply With Quote Multi-Quote with this Post
Old 01-09-2012, 07:07 PM   #15
tapeworm
tapeworm's Avatar
I put a triple layer metal gasket in my EF & it has tabs which stick out the side of the head. Perhaps if it has had metal one put in & you can see this. Also check for new sealant around the front of the timing cover and where the head meet. Best to ask previous owner though. It's tough to tell.
tapeworm is offline   Reply With Quote Multi-Quote with this Post
Old 02-09-2012, 12:49 AM   #16
Gavin Thomas
* 1973 ZF Fairlane 500 *
Gavin Thomas's Avatar
Remove head & check to find out for sure....
Gavin Thomas is offline   Reply With Quote Multi-Quote with this Post
