Old 25-07-2012, 01:09 PM   #1
Psi-Pop
on the way to the RSL
Psi-Pop's Avatar
Default Cage specs?
Has anyone got a copy of the newest roll cage specs that are required to run at Calder?
I was watching the highlights from Ford nationals on Gasolene and it didn't seem like some of the more street friendly cars had cages but were running 10.99 and faster. Or are they just tucked up and hidden nicely? Either way I'm going to start thinking about it for my car so I can run at Calder.
ED GLi - DOHC - GT42R - 2 Speed - 275 Radials- Moser 9"
8.9x@160mph+
Psi-Pop is offline   Reply With Quote Multi-Quote with this Post
Old 25-07-2012, 03:04 PM   #2
prasac
prasac's Avatar
Default Re: Cage specs?
check the ANDRA website might have specs on it.
prasac is offline   Reply With Quote Multi-Quote with this Post
Old 25-07-2012, 06:51 PM   #3
Mr. CVE
If it aint Blown it Sucks
Mr. CVE's Avatar
basically it is 42mm x 3mm wall tube.
standard 6 point. nothing exciting. joins must be notched, not squashed and welded.
Australia's fastest 3V n/a Ghia 13.52 @ 102 mph
@235 rwkw !!
Now turbo 11.77 @114 mph
320 rwkw, 810 nm torque, 280rwkw @3000 rpm !! :thebirds:
Now for sale
http://www.fordforums.com.au/showthread.php?t=11296772
Thanks to Snort Performance, Headsex and CVE
Street car DeTomaso Pantera
Drag car 1995 Mustang, Haleys Comet ( It's back !)
Power by CVE
Melbourne's first SNIPER Tuner :
Now tuning E series
Mr. CVE is offline   Reply With Quote Multi-Quote with this Post
Old 25-07-2012, 07:31 PM   #4
Pub247
Resident F1 Troll
Pub247's Avatar
Is material specified mr cve? Ie. seamless pipe? chrome moly?
Pub247 is offline   Reply With Quote Multi-Quote with this Post
Old 25-07-2012, 08:09 PM   #5
Ivan
Your choice of Chrome Moly or Cold Drawn Mild steel but it must be seemless. Size of the tube depends on which metal you choose. 6 point is only required 9.99s and quicker.
We purchase a mild steel kit from McDonald Bros in Thomastown.
Ian
Ivan is offline   Reply With Quote Multi-Quote with this Post
Old 25-07-2012, 09:34 PM   #6
Psi-Pop
Psi-Pop's Avatar
Cheers for the info fellas.
Got in contact with ANDRA and ordered a rulebook. Looks like a 6 point will be the go, I just happen to know someone with a notcher and mandrell bender, hey Pub? Lol
The aims for mid 9's so might aswel put the 6 point in instead of half doing the job until we get there. Now decisions on mild or chrome, ehhh.
8.9x@160mph+
Old 26-07-2012, 07:43 AM   #7
prasac
prasac's Avatar
get the chromoly, it's a ******** lighter, looks better and only a couple hundred bucks dearer.
Old 26-07-2012, 08:27 AM   #8
Psi-Pop
Psi-Pop's Avatar
Probably will go down that route, anything to save weight on a already heavy **** car.
8.9x@160mph+
Old 26-07-2012, 09:43 AM   #9
prasac
prasac's Avatar
not sure who sells chromoly in Vic, Rod Andrews here in Sydney sells it http://www.andrewsracecars.com.au/product_159.html
Old 26-07-2012, 12:01 PM   #10
Sorted
OzEcruisers PRESIDENT
Sorted's Avatar
Community Builder: In recognition of those who have helped build the AFF community. - Issue reason: For all the contributions you make to the AFF community.
You can do one run @ Calder and get a 10 then get booted off - maybe.......
Calder is a Faster Track than Heathcote so your time will be better
1994 Ford Fairmont EF NA 6cyl Man 3.9 diff Sedan
PROEF 13.46 @ 105.78mph
Tuned by DYNOMOTIVE
200BUX - AFF Drag Nats 2019 EF Wagon
Common knowledge that the more weight you take out of the car the less power you need to run the time.
Sorted is offline   Reply With Quote Multi-Quote with this Post
Old 26-07-2012, 12:53 PM   #11
Pub247
Resident F1 Troll
Pub247's Avatar
Quite a few joints in Melbourne sell McDonald's bro will sell length but there's a couple other joints locally sell it I know a steel wholesale place that should stock as they sell everything else
Old 30-07-2012, 10:34 PM   #12
ebxr8240
Performance moderator
ebxr8240's Avatar
Chromoly must be tig welded..
We just used an angle grinder with polishing disc to notch ends..
Dropped cage through floor to weld upper hoop then lifted & boxed floor..
Daily driver GTE FG..
Old 31-07-2012, 11:58 AM   #13
blownv8au
Pro Street Au Ute
blownv8au's Avatar
Thought i might aswell ask in here. Does anyone know they want a ute cage built at all?
Daily. AU XR8 s2 ute auto
Weekender. AU XR8 s2 sedan. 427 windsor, t56 magnum. 3.9 locker.
blownv8au is offline   Reply With Quote Multi-Quote with this Post
Old 31-07-2012, 06:13 PM   #14
justa6
justa6
justa6's Avatar
are you going to be making some blownV8au?
justa6 is offline   Reply With Quote Multi-Quote with this Post
Old 01-08-2012, 08:43 AM   #15
mex351
mex351's Avatar
I would contact Andrews race cars as a mate just got a cage done for his corty and the price for a ANDRA spec chrome molly weld in cage was less than half what others quoted him transported to his door.
mex351 is offline   Reply With Quote Multi-Quote with this Post
