Old 26-06-2012, 03:42 PM   #1
vesssh
Default AUII XR8 Ute Brake Upgrade
I am wanting to upgrade the brakes on my AUII XR8 Ute, after doing some research I have found a few different options.
First question, are BA/BF/FG standard Falcon callipers all the same?
If i was to go down the path of BA front callipers, is there anything else I need to upgrade? Rotors or Brake Lines or Brake Booster?
Is there any point upgrading the rear brakes? I have heard that Territory rear callipers can be fitted?
PS. The car is used for a tow car, so not wanting to go anything too big or wild :p
vesssh is offline   Reply With Quote Multi-Quote with this Post
Old 26-06-2012, 07:52 PM   #2
b2tf
not here much anymore
b2tf's Avatar
Default Re: AUII XR8 Ute Brake Upgrade
Go for BF XR6T/XR8 or Territory brakes, they are a bigger rotor and work well, and you wont have issues getting pads etc down the track. Cheap too, I picked up mine for about $350 and had the mechanic fit them, best money I've spent in a while. It all bolts up perfectly too.
2024 F150 XLT
Old 26-06-2012, 09:46 PM   #3
vesssh
So what do I actually have to get?
BF XR6T/XR8 callipers, rotors and lines? Anything else?
Will the standard wheels clear the brakes?
Is there any point upgrading the rears?
Oh and what about the booster? :p
Old 26-06-2012, 10:35 PM   #4
b2tf
b2tf's Avatar
Calipers, rotors and lines, pads will help too!
Lines will connect to the AU lines, no booster changes or mods required.
17" wheels will fit but you won't be able to go any lower due to the size of the rotors.
2024 F150 XLT
Old 26-06-2012, 10:43 PM   #5
raised by monkeys
raised by monkeys's Avatar
So what research did you do?
You'll just need to get the BA lines. Most people are going braided, but if you do, go braided all round not the just the front.
Can someone confirm??
cheers
Shaun
Current
SY FPV F6X Territory #214
Previous
FG MkII G6E Turbo built by Heinrichs Performance and Tuning
BFII FPV TORNADO #0021 351rwkw - Heinrich Performance and Tuning
"Milk is for babies. When you grow up you have to drink beer" - Arnold Schwarzenegger
raised by monkeys is offline   Reply With Quote Multi-Quote with this Post
Old 26-06-2012, 11:07 PM   #6
vesssh
So the AU lines wont connect to the BF XR6 Turbo callipers?
Old 27-06-2012, 01:13 AM   #7
nat75
did the Bf Xr8/6t swap to both my old au3 xr6 and my au3 xr8 and they bolt straight on. au brake lines work
nat75 is offline   Reply With Quote Multi-Quote with this Post
Old 27-06-2012, 11:53 AM   #8
vesssh
Just picked up some BF XR8 callipers for $110 each
Now to buy some rotors and pads.
What do people suggest for the rear? Or is there no need?
Old 27-06-2012, 12:03 PM   #9
vesssh
Just doing some research on rotors, are BA XR6 Turbo / XR8 rotors the same as BF XR6 Turbo / XR8 rotors?
Old 27-06-2012, 02:08 PM   #10
Gaz
Got Ghia?
Gaz's Avatar
No. They got the standard ba rotors unless you optioned the premium ones, which are different from the bf again.
2007 BF MKII Ghia V8 - BA GT Exhaust| F6 Intake | Superlows | 19" GT-P's | 30mm Swaybar | - Sold
2002 AU2 XR8 Ute - Manual | Leather | Injected LPG | Pacemakers
Gaz is offline   Reply With Quote Multi-Quote with this Post
Old 27-06-2012, 02:52 PM   #11
vesssh
Awesome, thanks for that.
Old 27-06-2012, 07:40 PM   #12
vesssh
Any point upgrading the rears?
Old 27-06-2012, 08:06 PM   #13
b2tf
b2tf's Avatar
My BF calipers had the BF lines attached and they connected up perfectly fine to the lines down to the wheel arch on the AU - so yes you can connect them without any issues. Just to confirm again - all you need are BF calipers, rotors, and pads. The rest will all bolt up to the existing setup on the AU.
BA and BF rotors are not the same, the BA ones are smaller.
I personally would not bother doing the rears unless a set came up for a very good price, most of the braking is done at the front anyway.
2024 F150 XLT
Old 27-06-2012, 08:07 PM   #14
vesssh
Unless a set of what came up for a good price? haha
Thanks for all your help b2tf, very much appreciated
Old 27-06-2012, 08:22 PM   #15
b2tf
b2tf's Avatar
Unless a set of rear brakes came up. Only reason I'd do mine is if the old ones wore out and theyre still the factory ones.
No worries
2024 F150 XLT
Old 27-06-2012, 08:26 PM   #16
vesssh
What I meant to say is, what rear brakes would you get if you had to replace the factory ones?
Old 27-06-2012, 08:53 PM   #17
b2tf
b2tf's Avatar
Territory rears.
2024 F150 XLT
Old 27-06-2012, 08:55 PM   #18
vesssh
Are they a straight bolt on for the ute with callipers on rotors?
Is there only one type of Territory rears?
Old 27-06-2012, 09:13 PM   #19
b2tf
b2tf's Avatar
As far as I am aware yes and yes.
2024 F150 XLT
Old 27-06-2012, 09:16 PM   #20
vesssh
Sorry for all the questions, but what about BF XR8 rear callipers and rotors, would they be a straight bolt on?
Old 27-06-2012, 09:30 PM   #21
BHDOGS
Really so bf calipers bolt straight on no need for shims?
Old 27-06-2012, 10:29 PM   #22
b2tf
b2tf's Avatar
No shims required. They went straight on to my AU3.
2024 F150 XLT
