30-05-2012, 05:14 PM | #1 | ||
As the title suggests are ba brakes (xr6t if its any different) a bolt on replacement onto a AU 99 fairlane i have a full set i took off my ba straight after i bought it .
FG xr6 lightning strike XF Monza turbo lpg EA fairmont ghia Carby turbo blow through c4 3.23lsd |
30-05-2012, 05:26 PM | #2 | ||
Just another mock-up..
From memory, you'll need to change all the front end to S2/3 AU.
Then the BA brakes will fit on..
Desire isn't driven by the heart, the mind or the wallet. Desire comes from another place. It's created by the smell of burnt fuel under full throttle and the look a car gives you when you're washing it alone at night... see my car here: Built my own TL50!!! [SIGPIC][/SIGPIC]
30-05-2012, 06:42 PM | #3 | ||
rexnet
XR6T might b bigger. if this is the case you want to make sure the wheels fit it all in. other wise not an issue
30-05-2012, 07:57 PM | #4 | ||
Lost Boost Gained Class
nope BA xr6 turbos have the same size brakes ans the Ba XT's and XR8's only in the BF they got bigger
2006 BF Fairmont Ghia
2001 AU Falcon |
31-05-2012, 12:55 PM | #5 | ||
Okay so if I put series 2/3 springs shocks
And stubs just thinking as fairlane needs shocks Anyway and thought while Ian there I can put The calipers and rotors that I have sitting here
31-05-2012, 05:34 PM | #6 | ||
also need the series 2/3 swaybar to i believe and lower control arms?
31-05-2012, 10:39 PM | #7 | ||
yes thats right
2001 AU Falcon |
