Old 29-05-2012, 04:44 PM   #1
sjako
Default How to remove serpentine drive belt from au 5 litre
Need help, going to replace water pump purchased a Max Ellery manual and it is very unclear on how to remove the belt. It states to fit a 3/8 drive socket to the idler pulley. There is no where that i can see to insert a drive socket as it has a nut on it and does not look like it will move to release tension anyway. The ony thing I can come up with is to put a 15 mm socket on my tensioner and turn it clockwise or anti clockwise is this what I do? It is the only thing that looks like it will move. Any help would be appriciated. any pictures would be great. Pity the manual is not much help The tensioner also has a nut on it.
Thanks
sjako is offline   Reply With Quote Multi-Quote with this Post
Old 29-05-2012, 05:39 PM   #2
fussy01
Default Re: How to remove serpentine drive belt from au 5 litre
thats what I do
fussy01 is offline   Reply With Quote Multi-Quote with this Post
Old 29-05-2012, 06:15 PM   #3
sjako
Thanks for the reply, do you know if it is clockwise or anti clockwise that you release the tension on the belt ?
Old 29-05-2012, 06:21 PM   #4
fussy01
Can't remember, just do it one way or the other. The tensioner will swing straight away. Its not tight.
Old 29-05-2012, 06:32 PM   #5
my67xr
my67xr's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: This contribution: 04 SX TX AWD, drama's replacing upper outer joints w/Nolathane replacements
on the bottom/lower section of the tensioner, is there a 3/8" square hole?
ba one close?, square hole is on the back
http://www.ebay.com.au/itm/2003-FORD...item3a74d079a5
on the 6cyls you turn the ratchet/bar clockwise to release the tension off the belt
Money Talks, but all i ever hear is it saying Goodbye!!
click below to view my build threads
67 XR Fairmont
04 SX TX Territory AWD
my67xr is offline   Reply With Quote Multi-Quote with this Post
Old 29-05-2012, 06:44 PM   #6
sjako
no square hole anywhere, only nuts and bolt heads.
Old 29-05-2012, 07:02 PM   #7
fussy01
see post #2
belt replacement will take less than 1min, its that easy
Old 29-05-2012, 10:01 PM   #8
It's 15 mm clockwise
aussiblue is online now   Reply With Quote Multi-Quote with this Post
