Old 26-05-2012, 05:55 PM   #1
sjako
Default Changing pads on AU series 2 with ABS
When changing pads on a AU series 2 with ABS do I need to undo the caliper bleed nut be for pushing the brake piston back to install new pads. If I do should I clamp the brake hose leading to the caliper before undoing the bleed nut. Any advise would be appreciated.
sjako is offline   Reply With Quote Multi-Quote with this Post
Old 26-05-2012, 06:48 PM   #2
GK
Walking with God
GK's Avatar
Default Re: Changing pads on AU series 2 with ABS
No need to touch the bleed nipple at all. You only touch this if you're flushing/changing fluid, but of course you'd do this after the pad change.
You just push the pistons back in with a g-clamp. Use one of the old pads so you don't wreck anything. Too easy!
GK
Now gone!
On LPG
Want a Full Life? John 10:10
Old 26-05-2012, 06:51 PM   #3
hagarone
hagarone's Avatar
Undo your caliper from one end of the slides, then tilt it up, use G clamp 2 compress the piston. don't touch line or bleeder nipple.
hagarone is offline   Reply With Quote Multi-Quote with this Post
Old 26-05-2012, 07:17 PM   #4
Cashie
Cashie's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: Multiple helpful contributions throughout the tech area.
If in doubt watch some youtubes, if still in doubt get a professional to do it.
Current Rides:
2017 Ford Mustang
2020 Ford Everest Sport
Past Rides:
2017 Kia Stinger GT
2008 FG XR6 Sedan
2008 FG G6E Sedan
2004 BA XR8 Sedan
2008 BF XR6 Turbo Sedan
2004 BA XR8 Sedan
2003 BA XR8 Ute
2003 BA XR6 Sedan
Cashie is offline   Reply With Quote Multi-Quote with this Post
Old 26-05-2012, 10:01 PM   #5
sjako
Thanks for the advice.
