Old 08-02-2012, 10:41 PM   #1
jaydee
jaydee's Avatar
Question Advice on injector O rings, what to do?
My son has a 97 Mazda 626 that has been running a bit crook. New plugs, leads etc, still rough. By the way its on dual fuel and is rough when on gas.
In desperation took it to the gas guy who put a new exhaust manifold gasket in which made a big difference (had a back fire sometime time ago which did this damage).
He said it's still sucking a bit of air hence running rough and said it was the injector O rings and needed replacing.
Son couldnt afford the extra work at that time so we said maybe later.
Now I'm OK with the spanners but never tried playing with injectors, how hard is it? Do I need special tools?
Also would I be better off just getting a new set of injectors, I presume they already have the O rings fitted. They're only about $140 for a set of 4.
Thanks in advance.
jaydee351
4DV8
jaydee is offline   Reply With Quote Multi-Quote with this Post
Old 08-02-2012, 10:51 PM   #2
z80
Default Re: Advice on injector O rings, what to do?
About 30 bucks.
Unscrew the injector rail....pull out injector, slip new o ring on, reverse the procedure.
Not rocket science....on most cars
z80 is offline   Reply With Quote Multi-Quote with this Post
Old 08-02-2012, 11:01 PM   #3
svo347
AFF's 1st DM.......
svo347's Avatar
Cheap insurance I'd go new. If you need a hand mate I'm willing to give u a hand for the costly price of a can of coke
Alloy headed 347ci EDXR8
13.21 @107.7mph
Originally Posted by zetec
Old 08-02-2012, 11:42 PM   #4
my67xr
my67xr's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: This contribution: 04 SX TX AWD, drama's replacing upper outer joints w/Nolathane replacements
yeah id just be replacing the injector seals,
falcon injector seals are only about $2ea,
its a mazda 4 cyl ( im guessing), if so it has 4 injectors, 2x seals per injector, so $16 maybe?
and iirc 4x bolts hold the injector rail to the motor.
Money Talks, but all i ever hear is it saying Goodbye!!
click below to view my build threads
67 XR Fairmont
04 SX TX Territory AWD
my67xr is offline   Reply With Quote Multi-Quote with this Post
Old 09-02-2012, 01:44 AM   #5
jaydee
jaydee's Avatar
OK thanks all for the tips.
SVO347, thankyou for the offer, I think I should be OK doesn't sound that big a deal, I should be right. Famous last words.
jaydee351
4DV8
Old 09-02-2012, 07:44 AM   #6
my67xr
my67xr's Avatar
yeah easy job, just a little wd/crc spray on the new ones to help 'em slip in
67 XR Fairmont
