Old 27-11-2011, 07:18 PM   #1
J_Putz
J_Putz's Avatar
Default engine swap procedure
What are the proper procedures for an engine swap with regard to paperwork and/or notifying the department of transport in QLD?
And if the transport department does need to clear/approve the engine swap will they also go over the rest of the vehicle and possibly fail the whole process for non engine related problems eg rust?
I'm not doing anything ****ster-ish. Just current engine is giving me grief and may have to replace it with another one of the same kind.
J_Putz is offline   Reply With Quote Multi-Quote with this Post
Old 27-11-2011, 07:40 PM   #2
El Venom
normality is boring
El Venom's Avatar
Default Re: engine swap procedure
All you have to do is inform them of the change in engine numbers if the motor our fitting is the same as the one your removing
Factory v8 with turbonetics 67mm turbo, haltech ecu, aeromotive and raceworks fuel system, cobra intake and a few custom bits thrown in
El Venom is offline   Reply With Quote Multi-Quote with this Post
Old 27-11-2011, 08:31 PM   #3
dave351cid
playing in my big shed
dave351cid's Avatar
i would say that they would want to sight the engine number.
unless the car is obviously unroadworthy they would probably be too busy to go right over it.
take it in on a stinking hot day and they will be wanting to get back inside to the aircond lol.
`75 XB FAIRMONT sedan . mushroom beige, injected 351, toploader, 9inch
`10 FG XR50 Turbo ute. Nitro blue, 6 sp Auto, Leather trim.
`04 BA RTV tray back, Red, V8 auto,
`04 BA XR6 Turbo sedan. Blueprint. auto, Leather trim.
`03 BA XLS ute . Acid Rush, factory lpg, auto,
`48 TEA20 Grey Ferguson,
`62 Willys 6-230 , 4x4 light truck
`04 Yamaha TTR 250
dave351cid is offline   Reply With Quote Multi-Quote with this Post
Old 27-11-2011, 09:43 PM   #4
J_Putz
J_Putz's Avatar
thanks chaps.
And then how do you get a VIN plate to to reflect the change in engine number?
Old 27-11-2011, 10:31 PM   #5
MYT
Cruizn in my 'lane
VIN doesn't change, it's noted on the database and will show up on the computer for any vehicle checks
MYT is offline   Reply With Quote Multi-Quote with this Post
Old 27-11-2011, 11:14 PM   #6
Jim Goose
Not a real hassle pretty sure you can even do it over the phone.
They wont need to sight the engine as long as its a straight swap with the same type of engine or one fitted from factory.
You've seen it, you've heard it and your still asking questions??
Don't write off the Goose until you see the box going into the hole....
Jim Goose is offline   Reply With Quote Multi-Quote with this Post
Old 28-11-2011, 08:28 AM   #7
J_Putz
J_Putz's Avatar
But on my VIN plate it gives both a VIN and engine number.
Old 28-11-2011, 10:23 AM   #8
Streets
Streets's Avatar
So does mine, but there's no need to make any changes on the plate. My car doesn't have the original motor even though it's written on the VIN plate. The DOT will just make the changes on their computer.
Streets is offline   Reply With Quote Multi-Quote with this Post
Old 28-11-2011, 12:37 PM   #9
dave351cid
dave351cid's Avatar
the vin plate states what the car was / had when it left the factory. it is illegal to change anything on the vin plate
transport dept will change the engine number on their records and on your rego papers.
i havent had to change engine number in qld , i was going on what we had to do in nsw when i said they would need to see the number. must be a bit more casual up here.
`04 Yamaha TTR 250
Old 28-11-2011, 03:30 PM   #10
tweeked
N/A all the way
tweeked's Avatar
Yes, just roll up at Queensland transport , they will sight the number in the block and go back inside and update the computer. Did this when I put in the US built motor.
BA GT
5.88 litres of Modular Boss Powered Muscle
300++ RWKW N/A on 98 octane on any dyno, happy or sad, on any day, with any operator you choose - 12.39@115.5 full weight
tweeked is offline   Reply With Quote Multi-Quote with this Post
Old 28-11-2011, 04:02 PM   #11
El Venom
normality is boring
El Venom's Avatar
You could be lucky and not even have them sight the car. I changed the engine number on my EL at the begining of the year and I just called up and the made the change over the phone
Old 28-11-2011, 07:52 PM   #12
J_Putz
J_Putz's Avatar
Are you sure about this? Because going off the engine number on the VIN plate the engine is apparently from a different model Ford.
Old 28-11-2011, 10:29 PM   #13
MYT
Cruizn in my 'lane
Different model or not any modification to a VIN plate is a big NO NO and seen in the same light as someone rebirthing a vehicle! As has been said above the DOT or what ever they're called in each state will update their database and it will show on your rego sticker and any authorities (DOT, Police, etc.) computer.
