Old 23-07-2011, 08:22 PM   #1
marcel_888
Default 2003 focus instrument cluster goes funny, wont start
Hello,
My mums focus is having some issues, every time i try to start it the instrument cluster goes all shaky in the dials, it's really odd, sometime things like the radio stays on after you take the key out even, other times the horn wont work properly, sometimes it will.. It was driving perfectly just after i drove it home from work, when i went to start it 20 mins later i experienced this issue.
heres a vid: http://www.youtube.com/watch?v=nS5A2esFbno
Ive checked all the fuses and tried to run diagnostic check by holding the odometer reset but it doesn't work, battery has excellent voltage, i can hear the fuel being pressurised but no spark occurs, engine wont turn over in any case, just clicking from the starter.
Sorry I don't know much about these cars and thought someone might have some idea.
thanks
marcel_888 is offline   Reply With Quote Multi-Quote with this Post
Old 23-07-2011, 09:49 PM   #2
Russ
Russ's Avatar
Default Re: 2003 focus instrument cluster goes funny, wont start
Can't be 100% sure but my guess would be the ignition barrel has bad contacts either that or you have an earthing problem. Try wriggling the key around in the ignition switch and see if you get constant flickering of lights and movement in the guage needles, if so the ignition switch is probably crook.
Old 24-07-2011, 09:10 PM   #3
4dlvr
4dlvr
http://fordforums.com.au/showthread.php?t=11217657
my thread a few years ago mate
96 EF FAIRMONT
Garrett gt40 turbo , iceman plenum, head ported, polished and balanced, wade turbo cam, wade double valve springs, bosch 023 fuel pump, 36lb injectors high flow cat, 4' dump and 2.5' redback exhaust.
215rwkw @7psi
4dlvr is offline   Reply With Quote Multi-Quote with this Post
Old 24-07-2011, 09:23 PM   #4
Russ
Russ's Avatar
At least now you know the car isn't possessed
Old 31-07-2011, 11:31 PM   #5
marcel_888
indeed it was the battery, thanks for your help. Surprised it didn't wan't to jump start at all, basically means your pretty screwed if your battery dies in an auto focus and don't have access to another battery. :S
