17-07-2011, 06:54 PM | #1 | ||
It's time for me to change the coolant in my sisters LS. I have read the hand book so I know it takes 6.5L and the mixture is 50/50.
I had a quick look at it in the garage today, it seems near impossible to drain the coolant without getting under the car. Is there a plug for the radiator? |
17-07-2011, 08:11 PM | #2 | ||
Yeah you need to get under the car. The coolant drain plug is on the bottom left hand side of the radiator (ie. Passenger side). If you're the right size, you don't need even need to jack the front of the car up - you can wiggle your way underneath the front. Having said that, it makes it much easier to access the plug if you do.
18-07-2011, 08:49 AM | #3 | ||
Thank you very much for that
18-07-2011, 08:26 PM | #4 | |||
You can call me Chris
'06 LS Focus Hatch -2 1/4" Lukey Exhaust -RDA Slotted discs/Greenstuff pads -Rear Whiteline swaybay -Lenso 18's w/Kumho rubber -Tinted Windows |
19-07-2011, 11:05 AM | #5 | ||
This is what I used (meets Ford specification): http://www.nulon.com.au/products/Red...rated_Coolant/
19-07-2011, 11:15 AM | #6 | ||
Thanks DZFord!
19-07-2011, 08:52 PM | #7 | ||
Torquer
How often should one change the coolant in their car?
2007 LT Focus TDCi S Bluefin Remap - K&N Apollo CAI - 2.5" Turbo-back Straight Pipe - 24mm Rear Sway bar - LT Zetec Bodykit - Black Projector Head Lights - LED Tail lights - DMB Overlays - Alloy Pedals - Scuff Plates - Sports Gear Knob - LV XR5 Springs - LV XR5 Wheels - Pirelli P-Zero Nero |
20-07-2011, 08:45 AM | #8 | ||
Ford recommends every 4 years for the red coolant they put in the LT Focus but may be less if you use aftermarket stuff as quality varies. Brake fluid should be changed every 2-3 years
