Old 15-07-2011, 08:57 PM   #1
weairy
Piston Broke
weairy's Avatar
Default MoTeC Engine Tuning
Hi guys,
We've just decided to upgrade to fuel injection in our off road racer, having a new engine and a basic system now. We've bought an M48 MoTeC ECU to match the fuel injection system. Has anyone ever tuned one of these?
Had some issues using Windows 7 64-bit, compatability just wasn't there, but worked around it, hoping this won't cause any issues.
- FOR SALE - 2009 FG XR6 in Velvet
weairy is offline   Reply With Quote Multi-Quote with this Post
Old 16-07-2011, 07:11 PM   #2
Powdered Toast Man
Professional Mouse Jockey
Powdered Toast Man's Avatar
Default Re: MoTeC Engine Tuning
Did a bit of toying with an M48 ECU back in uni (10 years ago) but we were using a Windows 3.1 OS on an ancient PC. Can't remember much now though.
Isuzu MUX for towing horses - currently no Fords in the stable
Time flies like an arrow; fruit flies like a banana. Groucho Marx
Powdered Toast Man is offline   Reply With Quote Multi-Quote with this Post
Old 16-07-2011, 07:57 PM   #3
StockieXR6T
StockieXR6T's Avatar
I tune them with some regularity, a number of my regular customers have them. I've been putting off buying a new laptop and even when I do I think I may put XP on it, some software, particularly the some older stuff I have just won't work on 7.
Joel
Black Mamba Racing Components
4B Fabrication & Performance Tuning
www. 4bfabrications.com.au
StockieXR6T is offline   Reply With Quote Multi-Quote with this Post
Old 17-07-2011, 05:30 PM   #4
madmelon
Yes I use MoTec on a weekly basis with the uni racing team, albeit an M800. We haven't tried it on 64 bit but I have major issues with it on 32 bit Win 7 (it used to run but no longer will, regardless or reinstall or what).
You should be able to use the compatibility component of Win 7 64 to run it, from what I understand.
madmelon is offline   Reply With Quote Multi-Quote with this Post
Old 17-07-2011, 05:47 PM   #5
weairy
Piston Broke
weairy's Avatar
Yeah, I thought that too, but I got the cheap-skate Home Premium version of it; no XP mode. Managed to get it to work by launching it in a DOS-emulator. Apparently they're a pretty handy unit, the M48, considering we're going to throw it in the dust and dirt
Old 17-07-2011, 11:44 PM   #6
superroo
You can't stop the signal
superroo's Avatar
Ditto to this comment. Have been using an m800 at uni for 2+ years now (good old FSAE). Have also done a M48 install on a side car for a mate. Have you tried the com's update that exist for window's 7?
I'm running everything off 64 bit windows 7 with no problems.
The m48 are still a great unit. There down fall though is the serial communication and the dos programming. The sidecar I setup (but didn't end up tuning) had more than enough resolution for the map and from reports back run's very smooth. Probably just as good as my detailed tune on the M800.
Weairy, If you want I could probably come up and set the ecu up for you and chuck a start tune in there.
Boffin
