Old 15-03-2011, 09:11 PM   #1
DZFord
DZFord's Avatar
Default Having a bad run with the Focus lately
Sorry guys, just need to vent some frustration!
1. 3 months ago, CV Boot fails and leaks grease all over my engine bay, $400 fix.
2. Soon after, the battery failed, called RACV, new battery installed.
3. 3 weeks ago, got rear-ended whilst stopped, going in for panel work on Monday.
4. Today - I was just driving home and as I turned into my street, I saw the battery light come on, and heard a really loud whining noise, which increases with engine RPMs = alternator fail!
The gods are frowning upon my car at the moment.
Old 16-03-2011, 03:57 AM   #2
photn
AFF Post NAZI
photn's Avatar
Default Re: Having a bad run with the Focus lately
Welcome to my world DZ, Car spent 10months off the road. Yes it was for a new engine and supercharger - but i also got 70% of the drivetrain replaced, New CV joints, clutch, flywheel, recondition gearbox, LSD, new boots etc etc. Also got a new battery and a new Altenator just for checks and measures.
Old 16-03-2011, 05:33 PM   #3
melbzetec
Old enough to know better
melbzetec's Avatar
Don't you hate it when you have to replace the bits that aren't sexy????
If cat converter fails you can replace with hi flow sports cat.
If shockers go, you can replace with Bilstein units.
But an upgrade battery, alternator, or CV joint boot? Damn, nothing sexy to be had there
Old 16-03-2011, 06:50 PM   #4
DZ Ford
Whats the kilometres on your 2006 job?
How much did those parts cost you. Got a 2006 just about on 100000kms.
I sometimes wonder whether its better just to trade it on a demo which doesnt break down and give you big surprise costs -but of ciurse you end up with a car loan costing you $100 a week plus.
I woudl be really interested to know what kms and cost you got hit with.
kevino is offline   Reply With Quote Multi-Quote with this Post
Old 16-03-2011, 08:32 PM   #5
DZFord
DZFord's Avatar
Photn, at least you came out of it with a supercharger! I think it was a great call on your behalf to have 70% of your driveline installed.
melbzetec, it's sad but true - absolutely no sexy bits to be replaced in my case.
Kevino, I've done 65,000km. The CV boot was $383 inc. labour at Ford.
Just got quoted $565 (!!!) for the alternator from Ford today. Ford is going to do the installation - I'm just way too busy with work at the moment to do it myself (its about 3 hours work), plus the car has to be ready for panel repairs come Monday!
Old 17-03-2011, 07:49 PM   #6
DZFord
DZFord's Avatar
Got the car back today, it runs well, although I'm much poorer now - alternator was $535. I'd love so say I love my new, shiny alternator but its hidden deep down in the engine bay and you can barely see it.
Old 18-03-2011, 11:18 PM   #7
DZFord
DZFord's Avatar
Bad went to worse today (for a while, anyway...). Was driving on the Maroondah Highway near Eastlink and all of the sudden..power steering failure...then I lost the radio, the dash, then all power. I managed to crawl to the side and pull over but I couldn't even put my hazards on...no power there either.
I started searching under the bonnet, and behold...the muppets at Ford forgot to secure the positive lead on the battery terminal after replacing the alternator. It was placed on, but not tightened down. It had almost managed to jump off the battery altogether.
Without a spanner in my car, I couldn't get it to stay on securely. So I rang the RACV - they couldn't send someone out because I was in a danger zone, I first needed to be towed out. 90 minute wait...no chance! I called a mate, he brought down a spanner and all was fixed.
I restarted the car and all was fine. I was thinking...why the power steering failure? Then I remebered the Focus has electro-hydraulic power steering.
Old 23-03-2011, 10:59 PM   #8
#Russ#Es#
Hello Koni's!
#Russ#Es#'s Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: This member has made a few valuable contributions to the Forum in the Focus section, seems to know exactly what he is talking about with his posts, which are helpful and concise.
You have had a bad time of it DZ! Hopefully that's it form a LONG while!
Interesting how Ford dealers (or any mechanic really) can get such simple things wrong. A couple years ago after a Ford service I noticed the bonnet moving at 110+ on the Princes Hwy coming into Syd (busy road). Don't know how the bonnet was down but not completely closed and not noticeable. Let's just say I pulled over pretty quickly, and the service dept got a not so happy call.
2006 LX FOCUS SEDAN
Titanium Grey, factory bodykit, slightly debadged
CSA Motorvatr 17's/Kumho KU31's, Eibach Prokit/Lovells rear springs, Koni Sports Kit
Lower airbox removed, K&N Panel filter
Momo gear knob + boot + pedals, Ghia boot garnish, Zetec Chrome interior door handles
JVC KW-XR816 Headunit + more to come...
#Russ#Es# is offline   Reply With Quote Multi-Quote with this Post
Old 24-03-2011, 04:50 PM   #9
DZFord
DZFord's Avatar
Finally got the car back today from the panel shop, repairs look great. Hopefully nothing else goes wrong!
Russ, my Ford service department also got a call, and they were very apologetic. Although mistakes do happen, not securing a battery lead is unacceptable when you're paying $100/hour labour.
Old 31-03-2011, 02:14 PM   #10
DZFord
DZFord's Avatar
Nope, the bad run continues.
Last night on the way home, check engine light came on. Plugged in my OBD2 Scanner...P0400 - Exhaust Gas Recirculation Malfunction. I checked the EGR electrical connection and everything seems to be fine there. Looks like I'll be stripping the EGR valve in the near future. Pain is, to do that, you need to drop the coolant...and I just changed my coolant not long ago!
Old 06-04-2011, 08:27 PM   #11
DZFord
DZFord's Avatar
You wouldn't believe this but today a workmate's alternator died, she also drives a Focus, the same model, built in the same year, same month (Dec 05 build, Jan 06 registered).
Looks like the alternator only has a 5 - 5.5 year lifespan.
Old 06-04-2011, 09:36 PM   #12
Riksta
Captain Malcolm Reynolds
Riksta's Avatar
Don't say that, mine's an October 2005 build! (Dec 05 1st registered).
Currently: 2014 Mazda6 GT (Daily) and 1999 Mazda MX5 (Fun Car)
Previously: 2001 Ford Escape XLT; 2010 MC Mondeo; 1984 FD LTD; 2001 AU2 Falcon Forte; 2005 LS Focus Zetec; 1988 RE Colt; 1982 RB Colt; 1974 KE20 Corolla
Originally Posted by Nikked
Riksta likes VN's so much, he has the ashes of a VN in a jar on the mantle piece, a vile of VN engine oil hanging from his neck and a BT1 build plate locked up in a safe, buried under 6ft of concrete.
Originally Posted by Day-mow
pretty much what has happened here is i trolled you. and it was fun.
Riksta is offline   Reply With Quote Multi-Quote with this Post
Old 06-04-2011, 10:29 PM   #13
DZFord
DZFord's Avatar
It could just be a complete coincidence....
....or maybe not!
Old 06-04-2011, 10:32 PM   #14
Riksta
Riksta's Avatar
Guess I'll find out soon enough hey!
Out of interest, what are the km's on the ones that have needed alternators?
Mine's now at ~112,000.
Old 06-04-2011, 10:43 PM   #15
DZFord
DZFord's Avatar
I think it is an age related issue, not a mileage problem. Mine has done 66,000km, hers has done 110,000km, so almost double.
Old 07-04-2011, 12:46 PM   #16
DZFord
DZFord's Avatar
Just an update here: she had it towed to Ford, who tried to charge her $310 for a new battery (she talked it down to $240) AND THEN quoted her $1260 for the new alternator (parts + installation). They said they could probably knock it down to around $1000 when she complained.
I'm not going to name the dealer in question here, nor am I posting this to "name and shame", but just a lesson to all of us to watch out, and to always get more than 1 quote if possible.
Old 07-04-2011, 05:04 PM   #17
Franco Cozzo
Thailand Specials
Franco Cozzo's Avatar
LOL $1000 for a new alternator.
Take it to an auto electrician, theres not much that goes wrong with alternators, the things that can go are voltage regulators, rectification diodes and the brushes.
You oculd get it reco'd for under $300 easy.
Old 11-04-2011, 06:00 PM   #18
XR5-Boy
You mad, bro?
XR5-Boy's Avatar
Yep. An auto electrician should be able to recondition it for way less. I did that when I had the Cougar as a new one was over 600 bucks! Got an auto electrician to replaced the brushes etc and any bits that had worn. Cost me 300 bucks in the end.
