Old 20-02-2011, 08:23 PM   #1
Dave_Obsession
Resident AFF detailer
Dave_Obsession's Avatar
Default Drivers side mirror has fallen out?
Just this afternoon in the course of a 2 minute trip to my parents place...
Used the mirror to see where I was whilst maneuvering out of my driveway...go to parents place...come out 20 minutes later, and my mirror glass is hanging out of the housing??
Managed to fit the main section back into place but there was a pin that has come out (and I'm not sure if anything else fell out).
Now it's not falling out but it's loose and has tilted downwards again. It does respond to using the electric motor but it's range of movement is very limited.
Are these things an easy repair, or is it worth just grabbing another one from the wreckers? The painted section on the back - does this just clip off so I can swap it straight over to another one??
Old 20-02-2011, 09:29 PM   #2
Mechan1k
Mechan1k's Avatar
Get a replacement one if you can ... you can get them through any wrecker ... or even brand new through online parts places for about $50 all in one piece.
The back scalp clips off in about 3-4 places ... a long flat blade screw driver helps.
Make sure you can an AU mirror housing ... as I think the B-series ones have different clips ... but look identical from outside.
Old 20-02-2011, 10:34 PM   #3
Dave_Obsession
how do the electrics hook up?
Old 21-02-2011, 02:31 PM   #4
LANKY 1
Are the Supercars on yet?
LANKY 1's Avatar
just a small plug with a couple wires when u take the whole mirror assembly off
A Ford win is a good win!
V8 dreamteam
1st: 2012, 2021
2nd: 2015, 2016, 2020, 2022, 2023, 2024
3rd: 2014, 2018, 2019
LANKY 1 is offline   Reply With Quote Multi-Quote with this Post
Old 22-02-2011, 09:42 PM   #5
Mechan1k
Mechan1k's Avatar
Just behind the sail panel on the inside of the door .... I can't remember with AU's now if the entire door trim needs to be removed to get the panel out
