Old 17-02-2011, 08:43 PM   #1
AUIIIute
Default How do I adjust my steering wheel? AU3 ute column auto 4.0
My owners manual says there should be a lever under the steering wheel, but mine honestly does not have one!? only a slit a 50c piece could easlily fit through.
Appreciate any help,
Cheers!
Ben.
AUIIIute is offline   Reply With Quote Multi-Quote with this Post
Old 17-02-2011, 08:47 PM   #2
XRGhia
meh.
XRGhia's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: Contributions in the technical arena.
its black if you sit in the seat, feel under the steering wheel to the middle close to you then work your way to the front of the car, you should find it
unless column shifts didn't come with it :/
Previous - BF XR6T - 325rwkw, 6 Speed Auto, Process West, X-Force and Turbosmart gear
XRGhia is offline   Reply With Quote Multi-Quote with this Post
Old 17-02-2011, 08:54 PM   #3
AUIIIute
Thanks will try one more time, unless im going nuts!
cheers
Old 17-02-2011, 08:55 PM   #4
mik
mik's Avatar
it (the handle) pulls down to unlock and sit s in up a recess in the colum when locked.
Old 17-02-2011, 09:11 PM   #5
Sox
RIP...
Sox's Avatar
Column shifts aren't adjustable.
Oval Everywhere...
Old 17-02-2011, 09:14 PM   #6
AUIIIute
I think you are right, column shift steering wheels cant be adjusted! oh well its not that bad anyway, cheers
Old 18-02-2011, 09:10 AM   #7
Mr Hardware
Flairs - Truckers Delight
Mr Hardware's Avatar
This is the correct answer.
Old 20-02-2011, 04:17 PM   #8
private9
www.TUFFCARPARTS.com
private9's Avatar
Column auto will not be adjustable mate!
