03-01-2011, 10:18 PM | #1 | ||
Lost Boost Gained Class
hey guys as the tital stats gages i need some info on them
ok well i was given a Oil /PSI gage and a Water/coolent temp one and ill like to wire them up so thay work as i have a mont my cluster has them already on there what would happen if i was to splice into the sencer lines?? will thay work right or give me a wrong reading
2006 BF Fairmont Ghia
2001 AU Falcon |
04-01-2011, 01:58 AM | #2 | ||
What's the point of putting them if your cluster already has them, and being an AU1, the oil pressure gauge actually works (it's not just an on/off gauge like the AU2 onwards)? Sorry, can't help with installing them, but not sure I would help even if I did know! You should get a monster tach while you're at it.
04-01-2011, 07:20 AM | #3 | ||
The resin for installing them is so I get a more detailed reading then what the cluster is giving me + thay where given to me. monster tacho no thanks I get enuf info from the cluster and that look really bad in a au
2001 AU Falcon |
04-01-2011, 08:24 AM | #4 | ||
Boost Addict
for the oil pressure gauge, you will require to install an oil pressure sensor and T-piece it into the oild pressure switch, go to pirtek or similar and get the appropiate pieces.
as for water temp, definately no, the AUs use a head temp sensor located at the back head, best option around that is, buy an EF/EL thermostat housing to replace the AU one, and install the water temp sensor into that. The general idea behind gauges is to have an additional set of sensor to monitor your engine when you suspect you have issues with your factory sensors, or you have a stupidly high strung engine, if you reuse stock sensors and it fails, both gauges will fail. as for positive and negative wires, you know what to do there :p
N12 Pulsar - sold Gen1 Liberty Turbo - sold VP Commodore Turbo - sold LN65 Hilux Turbo - sold EL31 Corolla Turbo - sold Ford AU Ute Turbo - sold Ford AU XR8 Sedan - 5.4l V8 Turbo (in the build) Ford BA XR6T Ute - daily driver Ford FG XR6T Sedan - cruiser do you see a general trend? I DO Can't live with it, can't live without it! |
04-01-2011, 11:19 AM | #5 | ||
Why not just put the cluster into diagnostic mode? It will give more detailed readings.
With an AU1 that has an oil pressure gauge already, there is no need to buy/fit an oil pressure sensor; they already have one.
05-01-2011, 11:31 AM | #6 | ||
Gotta love mods for the sake of mods lol
Current Blueprint 03 xr8 5 speed manual, Difilippo Quad Big Boy system, BPR CAI, BPR Custom tune, Underdrives 256rwkw BA manual Typhoon Fully optioned, 340rwkw@16psi (thanks Bluepower)! The old ride.... AU Fairmont, cammed beast, R.I.P you made my p plate years bearable! 150.8rwkw courtesy BPR |
05-01-2011, 06:19 PM | #7 | |||
Rob
I dont think you will be able to splice into the others, but i dont know for sure mate
Supercharged Nissan 350z 280rwkw Blueprint series 3 AU V8 manual |
