03-01-2011, 07:45 PM | #1 | ||
Mr Polish
g'day guys
I'm thinking about lowering the front of my car 1/2 to 3/4 of an inch with either Eibach or Koni springs some people I've spoken with say its not good to lower the car more than 1 inch because the rear IRS geometry will be changed and the rear camber will become more negative and chew the inside tyres out and then I gotta spend more money fitting camber/castor kits then of course there is the ride quality. I dont want it to go south. its lovely as it is with standard tickford ride height but the whole car is sitting equal, not the front being lower than the rear I want to give the front nose a drop so it gives the car a swoopier look what are the original tickford spring and shock measurements? If I decide to lower the front sooner rather than later, is it bad to leave the rear in standard form. can i get by with just doing the front without any problems later on the car is up on the hoist right now in our race team HQ and I value your opinions I dont want to get defected, have the ride become crap and make the stance worse than it already is I am going to contact a suspension expert here in Adelaide who specialises in old school muscle and comes highly recommended for modern fords too. as said above, my main concern is putting extra pressure on the IRS and screwing up its geometry by lowering it by 1 inch or more and chewing tyres. just for the sake of looks. thanks guys, I value your opinions
Detailology colour fx detail studio and R&D Lab SA's leader in auto detailing and paint treatments |
03-01-2011, 08:19 PM | #2 | |||
AU DIE HARD
I used super lows all round on mine dropped the front about 2" and the rear 1" with no adverse affect on the IRS then had a 4 wheel alignment the rears stayed near enough to the same as from the factory , front needed just a bit of a tweek , but got away with out a caster camber kit.it seems to vary a bit from car to car but for a 1" lower at the front than the back which is about ware mine ended up I can't see any problems
03-01-2011, 09:30 PM | #3 | ||
Same as Woosh here, i have sl kings right around in the Ghia with koni yellows and the ride is beautiful.
I had to have a Camber kit in the front and as Woosha has said the rear near stayed the same. |
03-01-2011, 10:08 PM | #4 | ||
Lower the front 3/4 inch and you won't have any problems whatsoever with either the front or rear camber (unless the car has had accident damage that hasn't been put back to factory spec).
Even if you dropped the front an inch or more you still won't have any issues at the back. You may have to fit a camber kit in the front though. The rear IRS on XRs already has camber adjusters and they have plenty of scope so never need replacing that I have ever heard. |
04-01-2011, 01:44 AM | #5 | ||
rexnet
if you only want to lower the front. i think eibach do a spring thats shorter then a low but taller then a super low. i know blue oval is running these and he's very impressed with them.
standard XR heigh is low. |
04-01-2011, 03:04 PM | #6 | ||
Critical Thinker
Matt's pretty aware of how mine sits at the moment with Eibach's. That being said, they are lower than 1". I think Matt is better off getting something that's less than 1" lower than standard XR height so that it doesn't look too uneven front and rear.
Kings low is pretty much what I would recommend based on Matt's requirements. There should be enough room for wheel alignment. When I fit my springs, I fitted the castor camber kit, but never really adjusted the camber much. Currently Im running 1.2-1.5deg negative camber to both wheels and 0.2mm toe in. Its just enough to avoid massive tire wear, and gives excellent handling and turn in. *disclaimer: the above specs work best with my car application choice, individual driver application & vehicle assessment is required for your car and should be checked by a professional. Some tire wear does happen with the above specs but it is marginal if tires aren't rotated regularly.*
"Everybody was KungFu fighting..." 2022 Mazda CX5 GTSP Turbo 2024 Ford Everest Trend 1967 Ford XR FALCON 500 Cars previously owned: 2018 Hyundai Santa Fe Highlander 2021 Subaru Outback Sport 2018 Subaru XV-S 2012 Subaru Forester X 2007 Subaru Liberty GT 2001 AU2 75th Anniversary Futura 2001 Subaru GX wagon 1991 EB XR8 1977 XC Fairmont 1990 EA S Pak 1984 XE S Pak 1982 ZJ Fairlane 1983 XE Fairmont 1989 EA Falcon 1984 Datsun Bluebird Wagon 1975 Honda Civic |
04-01-2011, 03:09 PM | #7 | ||
Lacking Imagination
I put King Springs Super Lows in the fairlane,
front end needed shimming and the rear end needed the adjustable camber bolts. Heasman's steering did the alignment, we did the spring swap!
My 11 Second AU Fairlane 364w | 225cc CNC | ---/---@0.050 | Morrison Motorsport ITB Manifold | MoTeC M150 (Engine Control) | PCS TCM-2800 (Trans Control) | 6800rpm Stall | 4R75W |
04-01-2011, 06:56 PM | #8 | ||
Fixing Ford's **** ups
On the subject of ride height. When you go to your suspension bloke, they should have the specs on hiow low you can go, to stay legal height. If they don't, get onto the transport dept website, or ring Regency park and get the info from them.
As for the camber issues. Only lowering the car will determine what else is needed. All the rest is speculation.
A wheel alignment fixes everything, when it comes to front end issues. This includes any little noises. Please read the manual carefully, as the these manufacturers spent millions of dollars making sure it is perfect.....Now why are there so many problems with my car, when I follow the instructions to the letter?....Answer, majority rules round here Lock me up and throw away the key because I'm a hoon....I got caught doing 59 in a 60 zone |
04-01-2011, 11:41 PM | #9 | |||
Resident AFF detailer
Order direct from the factory - $220 http://www.eibachdirect.com/p/523840/pro-kit.html They also have a free shipping promotion until January 10th.
05-01-2011, 12:07 AM | #10 | |||
rexnet
lame dont say that. i paid 255 for kings :( |
05-01-2011, 10:39 AM | #11 | ||
Critical Thinker
With the US dollar being equal or better than equal to AU$ its really a simple choice to get the Eibach's. They just feel more superior in my opinion, and this is coming from someone who has had Kings, Aurora, and Pedders springs.
05-01-2011, 02:25 PM | #12 | ||
i like the look of a lowered limo, but mine scrapes enough on the masses of dodgey gutters and speed humps in good old nth Melb, not to mention trying to get it on ramps or jacking the mongrel, how do you guys get by ?
05-01-2011, 02:32 PM | #13 | ||
Critical Thinker
Mine is fine on speedhumps and gutters. No scraping unless I have a full car load. Only place I had issues was getting on a ferry from Kadina to Pt Lincoln. But I always take it real slow getting over speed humps etc anyway.
05-01-2011, 03:35 PM | #14 | ||
I'm fine also - the rear mudflaps may scrape sometimes depending on the size of the speedhump, what's in the boot etc....but no problems otherwise, even with a full car.
05-01-2011, 03:39 PM | #15 | ||
I have to watch every little dip. And to jack it up I first have to drive it onto boards. And that's not even lowered!!!
05-01-2011, 05:19 PM | #16 | |||
rexnet
this is due the the fact i have a TS 50 bar as well as SL springs. as for jacking i use the side jacking point just behind the wheel with a small jack (tyre jack works alright) and then use my big jack to get under the front jacking point when i've got enough clearance |
05-01-2011, 06:24 PM | #17 | |||
Mr Polish
Why would they put live axle only when all of them are IRS
05-01-2011, 08:08 PM | #18 | ||
IIRC the XR6 HP are live axle? Only the XR6 VCT got IRS??
05-01-2011, 08:14 PM | #19 | ||
All XR8 Sedans, and VCT engined Falcon Sedans are IRS.
GT 335 11.3@124.1mph 383rwkw/513rwhp Forced Performance Tuned |
