13-12-2010, 11:51 AM | #1 | ||
Does anyone know the rule for the battery being in the boot for drag racing ?
Have been told i cant just use the plastic box that its in and that i have to secure it with a metal bracket |
13-12-2010, 05:49 PM | #2 | ||
Hmmmmm Mulberry....
Correct. Must have a bracket.
13-12-2010, 06:19 PM | #3 | |||
So could i just use the same bracket thats used when its in the engine bay ? Like this Last edited by 63futura; 13-12-2010 at 06:24 PM. |
13-12-2010, 09:53 PM | #4 | |||
Ian |
14-12-2010, 10:01 PM | #5 | |||
Broken
Hmmmm, that looks familiar....
The Scud GT 11.4 @ 128, 1.88 60ft. |
14-12-2010, 10:12 PM | #6 | |||
Hmmmmm Mulberry....
15-12-2010, 11:36 AM | #7 | ||
Do you have to have an isolater switch aswell ?
15-12-2010, 03:52 PM | #8 | ||
64 Deluxe 4 door
Im pretty sure you will need to seal the panel behind the rear seat, to create a firewall.
XM Deluxe FG XR50 BA Pursuit Ute |
15-12-2010, 05:41 PM | #9 | ||
Patience is a virtue
You only need a firewall if you have a fuel cell in the boot, and yes mate you must have an isolator if the battery is moved from it's standard location.
It must also cut the engine and all power when off. Basicly the charge wire has to go to the +ve on the battery and you pull power for the car from the switched side of the isolator not from +ve on the battery.
417ci CHI headed XD. Dynamic transmissions C4 Track times 60ft pb 1.365 (24-3-12) 10.173 @ 134.97mph 1/4 6.324 @ 108.93mph 1/8th PB SOLD |
15-12-2010, 06:58 PM | #10 | ||
64 Deluxe 4 door
Interesting.... circuit racing you must have firewall if battery is in the boot. Learn something every day
16-12-2010, 12:51 PM | #11 | |||
So i do have a fuel cell in the boot and the battery in the boot but all fuel lines are under the car (like a drop tank setup ) So i need to close in behind the back seat to make a firewall (can i use alloy) and need to fit isolator ? Where does the isolator go ? ie outside the car or in the boot or in the car Is there an Andra book for all this stuff ? Thanks for any help |
16-12-2010, 05:21 PM | #12 | ||
Hmmmmm Mulberry....
PM sent
17-12-2010, 01:59 PM | #13 | |||
All sorted Thanks Naughts |
