Old 08-11-2010, 10:20 AM   #1
brad24
brad24's Avatar
Default Tyre pressures at the track
What sort of tyre pressures should I be using at the drags on my XT?
Cheers Brad
'68 XT Fairmont, 9.48@141.6
'69 Capri 8.56@158.7
'95 triumph speed triple, '10 Fat Bob
My XT Fairmont
http://www.fordforums.com.au/showthread.php?t=11298079
My capri track car
http://www.fordforums.com.au/showthread.php?t=11492523
brad24 is offline   Reply With Quote Multi-Quote with this Post
Old 08-11-2010, 11:17 AM   #2
prasac
prasac's Avatar
what sort of tyres are you running? weight? hp?
prasac is offline   Reply With Quote Multi-Quote with this Post
Old 08-11-2010, 01:55 PM   #3
XT302
Details of his car here
http://www.fordforums.com.au/showthr...9&page=2&pp=30
It's my call pizzoff, and I just called it
XT302 is offline   Reply With Quote Multi-Quote with this Post
Old 09-11-2010, 07:24 AM   #4
prasac
prasac's Avatar
your best bet is to get a set of M/T Street Radials don't race on the street tyres.
Old 09-11-2010, 11:11 AM   #5
brad24
brad24's Avatar
Originally Posted by XT302
Thanks XT302
I was planning on running the MT street radials, sorry I should of mentioned that. the car would be around 480 - 500 HP & I reckon about 3600 lbs with me in it
So what pressures do you think would be best?
Cheers Brad
My XT Fairmont
My capri track car
Old 09-11-2010, 11:17 AM   #6
xagsjoe
Patience is a virtue
xagsjoe's Avatar
15-18psi mate. Outside these ranges won't do much good. Checkout the M/T website for their bulletins and reccomendations.
417ci CHI headed XD.
Dynamic transmissions C4
Track times
60ft pb 1.365 (24-3-12)
10.173 @ 134.97mph 1/4
6.324 @ 108.93mph 1/8th PB
SOLD
xagsjoe is offline   Reply With Quote Multi-Quote with this Post
Old 09-11-2010, 12:10 PM   #7
brad24
brad24's Avatar
Thanks Joe
& for anyone else who wants to know
http://www.mickeythompsontires.com/tech.php?bulletin=s3
My XT Fairmont
My capri track car
Old 09-11-2010, 12:47 PM   #8
xagsjoe
xagsjoe's Avatar
Are you going to invest in some caltrac's or slapper bars? They are a good investment. I went a 1.48 60ft on oztracs this last wknd so they help hook you up
Track times
SOLD
Old 09-11-2010, 02:14 PM   #9
brad24
brad24's Avatar
Ive bought a spare set of convo rears to put the MT street radials on.
I figured Id run with them first & see what happens.
How much are oztracks & where do you get them from?
Ive never driven a car down the chute but I have had my current bike & my last 2 down there with a best time of a low 11
Any advice for a first timer would be appreciated
Cheers Brad
My XT Fairmont
My capri track car
Old 09-11-2010, 02:38 PM   #10
brad24
brad24's Avatar
What are the Macdonald Bros version like?
http://www.mcdonaldbrosracing.com.au/trackrods.html
My XT Fairmont
My capri track car
Old 09-11-2010, 07:00 PM   #11
XT302
Brad this one doesnt run anywhere near these pressures (22-24 rings a bell) , using slidealinks though
http://www.fordforums.com.au/showthread.php?t=11258423
Old 09-11-2010, 08:38 PM   #12
Ivan
I'm running 18psi and can go to 14 if I have to but only on the strip.
Ian
Ivan is offline   Reply With Quote Multi-Quote with this Post
Old 09-11-2010, 10:57 PM   #13
rusty 351
rusty 351's Avatar
there nicely made and rays good to deal with,
i bought those then got some 10mm lower plates made up to weld the rear mount to.
dont forget to reinforce the rear spring perches as well to stop them breaking off
rusty 351 is offline   Reply With Quote Multi-Quote with this Post
Old 10-11-2010, 10:03 AM   #14
brad24
brad24's Avatar
Rusty
Were the macdonald brothers version of the traction bars a "bolt up fit" or do they need some mods to fit?
Cheers Brad
My XT Fairmont
My capri track car
Old 10-11-2010, 06:44 PM   #15
rusty 351
rusty 351's Avatar
Rusty
Cheers Brad
apart from welding the rear tabs to your lower leafspring bracket they just bolt in,
although i did have to grind a bit off one of the bolt heads either side because it was just touching the chasis rail when it pivoted.
just check that when you bolt it all in to dummy up where you need to weld the rear mounts too. (weld the brackets so you have plenty adjustment either way so you can back them off or put a few turns off preload on the leaf)
Old 16-11-2010, 08:41 AM   #16
XT302
So when do you plan to give the track a touch up ?
Old 16-11-2010, 08:35 PM   #17
brad24
brad24's Avatar
Tomorrow week if everything goes to plan. I bought a set of MT ET streets in 275/50/15 But they were rubbing badly on the passenger side. I changed the wheels to another set with 1/2" more backspace & got the guards rolled today & now they arnt rubbing.
I'll let you know how I go.
Cheers Brad
My XT Fairmont
My capri track car
Old 16-11-2010, 08:44 PM   #18
XT302
Sounds sweet a much wider radial than Blocker runs (235/60/15) enjoy your racing :-)
Old 17-11-2010, 11:32 AM   #19
63futura
63futura's Avatar
Cheers Brad
Where did you get ya guards rolled and what did it cost ??
Looking at doing the same thing
63futura is offline   Reply With Quote Multi-Quote with this Post
Old 17-11-2010, 01:08 PM   #20
brad24
brad24's Avatar
Sam @ Vulcan panel in Canning Vale did the work for $200
Seems to know his stuff
He runs a EK that does 9.1
My XT Fairmont
My capri track car
Old 21-11-2010, 07:41 AM   #21
dieseltrain79
Dont run any less than 14psi in ET Street Radials . They will start to loose traction and your 60' will go backwards .
I always run 16-17psi in mine .
1998 AU VCT Ghia - Stock as a rock - Wifes car
1991 Toyota Soarer TT - 11.72 @ 116.7mph
2004 Ford Escape XLT V6 - Family Ride .
dieseltrain79 is offline   Reply With Quote Multi-Quote with this Post
