Old 27-10-2010, 03:50 PM   #1
imaz
Default Boot opens itself
My LS Sedan boot has been opening/unlocking itself intermittently. It has happened when parked, and also when I have just driven off...
You can actually hear it open, like as if you have pressed the keyfob etc.
Anyone know what might be the cause? The damn open button on the boot lid itself works sometimes, and sometime not. I quite hate it, as this happened since I bought the car new 3 years ago.
Regards
Imaz
2009 FG Falcon XR6 Sedan, Octane.
2012 WK2 Jeep Grand Cherokee Limited, Mineral Grey.
imaz is offline   Reply With Quote Multi-Quote with this Post
Old 27-10-2010, 05:26 PM   #2
marg99
it sounds like the lock electronic actuator on the boot may be faulty or the lock now misaligned for some reason.
marg99 is online now   Reply With Quote Multi-Quote with this Post
Old 27-10-2010, 11:40 PM   #3
imaz
The actual motor for the boot is fine, as the keyfob boot button never fails and is the only reliable trigger to open the boot.
Its the handle button on the boot lid that sometimes works and sometimes does not, and sometimes opens itself! LOL
What is a replacement button worth?
Regards
Imaz
Old 27-10-2010, 11:48 PM   #4
imaz
Common problem and no success > http://www.fordownersclub.com/forums...howtopic=11292
Regards
Imaz
Old 28-10-2010, 11:29 AM   #5
somers181
somers181's Avatar
This happended to me a few months back in my LS and i posted a similar thread and the solution was to replace the battery in your key!!!
My tailgate was openning all the time whether stationery or driving and was driving me nuts trying to figure out what was wrong without going into ford dealership and them charging me a fortune to fix........
I just swapped it over with the spare key as this was quick fix and it worked perfectly.......
goodluck, Rick
Capri Car Club of NSW,
Keeping the Legend Alive since 1985
somers181 is offline   Reply With Quote Multi-Quote with this Post
Old 28-10-2010, 12:14 PM   #6
imaz
goodluck, Rick
Are we really that stupid? It happens when you dont even press the keyfob, which means even when driving. Pressing the keyfob boot release actually never fails and works everytime I want to open the boot. Pressing the boot release on the BOOT ITSELF sometimes work and mostly doesnt.
Regards
Imaz
Old 28-10-2010, 01:13 PM   #7
somers181
somers181's Avatar
Not sure i follow your query......... who are you saying is stupid????? Ford Design?????
Have you tried changing the battery in your key or use a spare key with the other one moved away from the car because thats probably causing the problem....
I would be driving along and can hear the latch on the tailgate open itself, it could happen as many as 3 - 4 times in a row and it would happen when the car was stationery, parked or driving........ it lasted for about 2 weeks until i changed over keys..........
Old 28-10-2010, 02:20 PM   #8
imaz
okay, I will try the other key.
But are you able to open your boot using the boot release on the boot itself? Mine often does not work, OR it allows me to open it once, then if I close it I wont let me open it again! WTF, and then i have to use the key fob.
Regards
Imaz
Old 31-10-2010, 06:43 PM   #9
imaz
I took my boot apart today and got to the micro switch. Damn this is so tiny and really should not be used in this application. All I have to say to Ford, it was a bloody poor design if they had used their head, the microswitch is too sensitive for this application and the conditions its suppose to withstand(ie rain).
Mine did not appear damaged in anyway nor did it look like it corrode so I reassembled everything. Its just a senstive switch and at certain angles, it wont work etc. The overall switch is 1/5 the size of a 5cent coin, so go figure.
If it shits me too much, I will cut the wire to it and just use the keyfob for opening.
Regards
Imaz
