05-09-2010, 04:34 PM | #1 | ||
I've had my LV series XR5 since late May this year. It's great but one thing about it still bugs me.
That clutch. I'm hoping that mine is simply not adjusted correctly and that Ford can tweak it when I take it in for it's 3000k 'service' (read "quick inspection"). The problem is that the 2 stage spring action goes from very light to very sudden right at the take-up point. Now, if you're letting the clutch out slowly you can control it and when you're moving and you can let it out much quicker if you match your revs, it's OK. The problem is when you're in stop/start traffic and you just want to gently nudge yourself along. My clutch is very hard to control at this point and I've acted like a bikini model and stalled it a couple of times. I look silly in a bikini so I'm hoping someone here can tell me if the 'over-centre helper spring' (or whatever they use in this) can be adjusted. Is the XR5 clutch hydraulic or cable or some servo/assisted device? Surprisingly, it seems a bit better when it's stone cold but that may simply be because the idle revs are higher and so the 'bite' is smoothed out anyway. Any advice will be rewarded by NOT receiving pictures of this middle-aged man in a bikini. |
05-09-2010, 04:46 PM | #2 | ||
Barra Turbo > V8
I cant say ive had the same issue with my 5, the clutch in my 5 is very forgiving and to date not one stall. Id mention it to the dealer when its time for the 3000km once over. How many on it now?
-2011 XR6 Turbo Ute - Lux Pack - M6 - OEM+ -2022 Hyundai Tucson Highlander Diesel N Line |
05-09-2010, 05:17 PM | #3 | ||
DJM83 - it's just coming up to 3000ks actually and it's going in for it's 3000k this week. I just wanted some advice beforehand in case they try to tell me it's normal.
05-09-2010, 05:21 PM | #4 | ||
Barra Turbo > V8
Welll as i said mine is pretty easy to control ive only had mine 2 weeks though. So it does indeed seem a little strange
05-09-2010, 08:34 PM | #5 | ||
You mad, bro?
Hey Skid,
I've had my LV since January and haven't had a prob with the clutch. I found it was very easy to control (even after not having driven a manual for a number of years). I'm in start stop traffic most days and I can roll it very easily. Get them to check it at the service to see if it's not behaving as it should.
2009 LV Focus XR5 Turbo Performance Blue SFS 2007 Best Cougar, SFS 2010/2011 Best Focus XR5
05-09-2010, 10:48 PM | #6 | ||
OK cats, it goes in this Thursday. I'll keep you informed of what they said/did.
06-09-2010, 10:15 AM | #7 | ||
Knows nothing. Apparently
Have you stuck your head under the dash to see if one of the springs is broken? It used to be a common problem on the old LR foci (which IMO had a heavier clutch than the 5) but haven't heard of the issue in any model since.
2008 Electric Orange LV XR5. With dreamscience strategem SCT, K&N 57i Gen2 cold air intake for more fun and demonic vaccum cleaner noise!! 1975 Mitsubishi/Chrysler GC Galant 2-door Hardtop. 4G63 DOHC heart transplant nearly complete!
Check out the build over here |
06-09-2010, 11:20 PM | #9 | |||
My problem is the sudden extra spring-back right where you want to control the pedal position. |
08-09-2010, 02:14 PM | #10 | ||
Hmmmm....sounds like a manny issue (read:bourney's mate) sadly we still don't REALY know what's wrong with that car....3 clutches, 2 master cylinders, 3 slave cylinders and still has a SLIGHT 2 stage feel returning on the new RS clutch.
Master cylinder was the main issue, but the clutch which was fitted to it after the OEM one was slipping and giving that weird feeling didn't take incredibly well to the car. Hopefully it'll be simply a 'fault' with the master cylinder....no tweaking available however. they're not serviceable..they either work or they don't...and if they don't they have to be replaced. Where are you taking it for it's 3K POM inspection? |
10-09-2010, 11:30 PM | #11 | |||
I took it in on Thursday and they seemed to be interested enough to talk to me about it and even let me try to demonstrate the problem when I went to pick it up after they told me it checked out OK. Because the problem seems to vary with frequency of use, it was hard to make this issue appear when I needed to show it up. I drove slowly around and around their car park trying to make it grab suddenly but the bloody thing drove as smooth as President Obama's limousine! So I drove it back to work feeling like a bit of a idiot. I drove it home afterwards and it was perfectly OK. This morning, it reverted to dog-clutch mode a few times again and I will continue my search for answers. Everything about the rest of this car is so good, I'm driven to sort it out. If it was a crud-heap I wouldn't care. |
11-09-2010, 08:44 AM | #12 | ||
Barra Turbo > V8
Hope you get it sorted out mate
11-09-2010, 07:32 PM | #13 | ||
Aka.Barnesy
I've found that most XR5's have a limited take up on slow take ups as in traffic, as they don't use a cushion spring set up in the clutch plate..So end result is no Give...
It gives the in or out effect. WE have fitted S60R clutch kits to them, and a much more progressive feel due to them fitting cushion springs to the plate.. |
13-09-2010, 11:49 PM | #14 | |||
14-09-2010, 08:35 AM | #15 | ||
IMO, if you are going to replace the clutch, get the RS clutch.
Skip past the S60, go straight to the RS.. It's springer than stock for sure, but god it feels good, specially when doing quick shifting.
flickr |
21-09-2010, 03:00 PM | #16 | ||
Hey Skid Marx
I know exactly what you mean, mine does the same sometimes in slow traffic or when I'm not paying attention taking off from lights say. It suddenly drops and I lurch forward. Light pedal when fully depressed, then when you take up your foot, it can spring up quickly. Mine has done this the same way every time since I got mine in May this year too. I suspect it's just a Ford thing but, most probably like yourself, if there is a fix or a tweak, I'd love to hear it!! I'm no mechanic but I'd say it's just he way they are a replacement clutch (unless aftermarket perhaps) might not resolve the issue. Aye, Mick
Mine - Silver '10 LV XR5 Focus - Stock Hers - Silver '06 RWD 7 seat Ghia Territory - Stock |
21-09-2010, 06:28 PM | #17 | |||
what-tut-tut-tut
I've had nothing but dramas with those idiots, will never deal with them again. |
