Old 21-08-2010, 08:35 PM   #1
RspecAU
BA GT-P Owner
RspecAU's Avatar
Default Tunning the XR8
I been thinking about what to get to tune the XR8 with and i'm looking for some input on which one would give me a better result in power output. I'm not totally conviced that the Xcal tuner box is the way to go, as we have all seen that BrockyB8 has done an awesome job with his I6 by not using the Xcal.
I do have a good cam for it of hand i can't remember the specs, AFR 165cc heads and match ported the intake to the heads. I am thinking about getting an ICE Ignition set up pending on the cost. The bottom end is pretty much stock with the exception of a main bearing girdle.
So wich one will serve me better?
Cheers Mark
DAILY DRIVER/TRACK CAR
BUILD NUMBER 006
Old 21-08-2010, 09:10 PM   #2
SLO AU XR8
BrockyB8 is running a Wolf V500, big difference between full control aftermarket ECU's and tuned stock ECU's.
GT 335
11.3@124.1mph
383rwkw/513rwhp
Forced Performance Tuned
SLO AU XR8 is offline   Reply With Quote Multi-Quote with this Post
Old 21-08-2010, 09:23 PM   #3
philstoj
philstoj's Avatar
The SCT tuning is the easiest option, and cheapest.
Old 21-08-2010, 09:28 PM   #4
Whoosha
AU DIE HARD
Whoosha's Avatar
AU1XLS runs the Haltech set up. Problem with the Au is you still need the factory ecm to run the smart lock ext, and it get expensive to tune them. stick with the Xcal 3 IMO
Originally Posted by Riksta
Old 21-08-2010, 09:32 PM   #5
crakrz
T3 TE50 Blueprint
Technical Contributor: For members who share their technical expertise. - Issue reason: Craig has shown and shared an outstanding amount of knowledge in the field of Tuning. Craig is only to happy to share with anyone that asks his knowledge on the EEC tuning system, in particularly in the use of Moates Quarterhorse and Binary Editor.
"thinking about getting an ICE Ignition set up pending on the cost"
What do ICE do for the AU's synchroniser. Or are you going to go to a dizzy instead with an aftermarket ECU?
-Craig
crakrz is offline   Reply With Quote Multi-Quote with this Post
Old 21-08-2010, 09:51 PM   #6
RspecAU
BA GT-P Owner
RspecAU's Avatar
Well that could sway me as I don't want to mess the smart lock system up and i don't need a big tunning bill
-Craig
I was thinking ICE just to put a better ignition system but i have had a look at whats out there for the AU and the dizzy is to big to fit under the engine cover that i just bought
BUILD NUMBER 006
Old 22-08-2010, 08:35 AM   #7
CFOUR
The Destroyer
CFOUR's Avatar
why not get a tweeker and tune it yourself?
Toy- Blown XR8 Ute. Black on black
"Front-drive cars are for children"
CFOUR is offline   Reply With Quote Multi-Quote with this Post
Old 22-08-2010, 10:46 AM   #8
The Monty
Just slidin'
The Monty's Avatar
Why are you not convinced about the Xcal 3?
Have you heard bad things about them?
All Ive heard is praise. They are cheap, easy to use, full of user features (data logging, owner adjustments) and anyone can tune them.
MD Mondeo - For the family
NP Pajero - For the adventure
Old 22-08-2010, 11:08 AM   #9
ratter
ratter's Avatar
You can not tune with the X3 unless you have the advantage software.
If the supplier allows 'end user adjustments", you can make a few tweaks to an existing tune, but not tune a car from scratch.
The factory ecu will be better than most aftermarket ecus and control of spark through an ecu will always acheive better results than a distributor ever will, even though a distributor may match top end power.
Pit Lane Performance
Old 22-08-2010, 02:13 PM   #10
The Monty
Just slidin'
The Monty's Avatar
Ratter, I wasnt implying you could tune it yourself, I was just saying there is user adjustments.
Old 22-08-2010, 02:24 PM   #11
ratter
ratter's Avatar
that's ok, just wanted make sure you knew before possibly buying 1, thinking it could be done
Old 22-08-2010, 04:02 PM   #12
The Monty
Just slidin'
The Monty's Avatar
I only have a couple of things unlocked on mine, like timing, and rev limiter, and something else (cant remember) might be fuel?
Old 23-08-2010, 01:42 AM   #13
RspecAU
BA GT-P Owner
RspecAU's Avatar
As i wouldn't know what i was doing i'm no tuner
No i havn't heard anything bad about them i just want to know what else is out there.
BUILD NUMBER 006
Old 23-08-2010, 02:10 AM   #14
The Monty
Just slidin'
The Monty's Avatar
Unichip, Chiptorque chip, EMS, XCal, and I think Sniper tuning?
Old 23-08-2010, 08:20 PM   #15
Windsor220
Now Fordless
Windsor220's Avatar
Yeah I used Sniper.
Old 25-08-2010, 06:39 PM   #16
Bundy
All Ford Club Life Member
Bundy's Avatar
Another option -Live tune straight into the computer, no flash box or aftermarket chip need.
I've done this with mine, chiptorque on the gold coast did it, I don't know of anyone else down your way though.
Worked AU XR8 Ute - Toy
Std FG XR6T Ute - Daily
Supercharged BA 6 Ute - Wife's daily
351W F150 93 XLT 4x4 Supercab
Bundy is offline   Reply With Quote Multi-Quote with this Post
