07-07-2010, 12:17 AM | #1 | ||
Hello Koni's!
I've been looking at the price of Koni Sport dampers for a while now and the time has come to bite the bullet and buy a set - the Eibach springs have been installed for over 50,000km with the stock dampers.
To source these locally I have received quotes for around $1500 (plus fitting). With shipping, price comes down to AU$1000 from http://www.demon-tweeks.co.uk/ More info here...http://www.demon-tweeks.co.uk/Perfor.../0/85855/28660 They have adjustable on-car rebound damping for the fronts, rears need to be adjusted when installing. Have heard everywhere, including from Koni's Aust. distributor, that you set the front and rear to the softest setting initially, so this isn't a huge problem. Wondering if anyone would be interested in grabbing a set? Am waiting on Demon Tweeks to get back to me about a group buy, thought I would see if anyone was interested in the meantime...even if they don't offer a group buy, you just saved $500! Otherwise, hope to have them installed (might try myself) within the next 6 weeks if I order them in the next week or so. I realise they're not a cheap buy, but thought I'd give everyone the chance to save a few $$$ if they were thinking about it.
2006 LX FOCUS SEDAN Titanium Grey, factory bodykit, slightly debadged
CSA Motorvatr 17's/Kumho KU31's, Eibach Prokit/Lovells rear springs, Koni Sports Kit Lower airbox removed, K&N Panel filter Momo gear knob + boot + pedals, Ghia boot garnish, Zetec Chrome interior door handles JVC KW-XR816 Headunit + more to come... |
07-07-2010, 11:18 AM | #2 | ||
You've got me thinking...
I'm sure the Eibachs would great when coupled with the Koni shocks. However, $1000 on shocks is a little hard for me to justify when you can get the Bilstein coilover kit (ride height adjustable) for a tad over $1000 as well. |
07-07-2010, 03:03 PM | #3 | |||
Hello Koni's!
I'm pretty happy with my ride height so don't see the value in adjustable height. I do see value in adjustable damping though. Plus I've already got Eibachs installed, would be a waste to ditch them (despite being able to sell them) and install coilovers. I have thought long and hard about the damper vs coilover debate though. If I had stock suspension I would seriously consider getting decent coilovers, but once I install the Koni's (and hopefully setting the rears to full soft is best for my setup), I shouldn't have to play too much with finetuning the damping rate. At least the fronts will be easy to change.
07-07-2010, 09:36 PM | #4 | ||
Good points there.
I am not sure if I am happy with my ride height though. Did you Eibach's leave the rear a little too high compared to the front? I remember a forum member removing the rear Eibach's and putting on a set of Lovell's springs. Just can't remember who... |
07-07-2010, 10:04 PM | #5 | |||
Hello Koni's!
Pretty sure there would be more springs out there too since I bought mine back in '06
07-07-2010, 10:23 PM | #6 | ||
So it was you! I thought it might have been but wasn't 100%.
I think Eibach just dropped it 30mm all round, which still leaves the rear higher than the front. Off the top of your head, can you remember how much a set of Lovell's rear springs set you back? The only other springs I've come across are from Weitec (made by KW suspension). |
07-07-2010, 10:38 PM | #7 | |||
SUMPA's sedan
my supalow lovells were only $360 for front n rear. i thort that was pretty good price. rear is very low, i think lower than the front from memory
'07 sapphire black manual LT focus zetec sedan 6.5" alpine dvd player - alpine splits - response amp - alpine 12" sub - lovell's supalow springs - LV XR5 Focus wheels - Kumho KU31's - black leather - tint
07-07-2010, 10:49 PM | #8 | ||
Hello Koni's!
It was a while ago, but I think they were Super Lows. Set of 4 around $280 http://cgi.ebay.com.au/Ford-Focus-2-...item2c55519033
I remember at the time you could buy them in pairs too. And mine are blue.
08-07-2010, 11:39 AM | #9 | ||
Thanks for the info guys, this is probably something i'll look into. Any rear camber issues? Any ride comfort issues on the standard shocks?
08-07-2010, 01:46 PM | #10 | ||
Hello Koni's!
The rear camber of my sedan actually looks a little aggressive, yet the rear tyre wear is no different to that of the fronts.
An old photo - not the best example of the rear camber, but you can see the rear is a little more aggressive than the front: You can get rear camber adjustment kits from a number of places, including Pedders: http://www.pedders.com.au/catalogue Select our model and scroll down to 'Rear alignment products' - pretty sure that is the part number, and from memory they aren't too expensive. Something I need to look into getting with the new dampers. With the Eibach's/Lovell's and stock dampers, the ride is pretty forgiving. As time has gone on though, the stock dampers have really started to show their age + effect of not being perfectly matched (damping-wise) to the springs. A new set of sport dampers all around will definitely make a huge difference to the ride quality. Over 60,000km's out of a set of stock dampers is not too bad given they're essentially being used in a way they weren't designed to. Plus I really like the fact the Koni's (and most good quality dampers) can be revalved, so you can take them with you to another car (that they fit) or sell them for decent $$$.
16-07-2010, 05:07 PM | #11 | ||
Hello Koni's!
Just a quick update - ordered the Koni's the other night from Demon Tweeks. Cost me $980 with shipping, which was the best price I could find anywhere.
Imagine it will take a few weeks for them to arrive - might post some pics when they arrive + are installed.
16-07-2010, 11:08 PM | #12 | ||
Hi Russ, thanks for the info on the rear camber / camber kits.
You are so lucky that the shocks + shipping came to <$1000. When I imported my wheels, the shipping + goods came to just over $1000 which means I had to add on customs duty, GST and customs clearance fees, which cost me an arm and a leg. |
18-07-2010, 09:37 PM | #13 | ||
AFF Post NAZI
Make sure you PM the GM's regarding this Group Buy or they will shut the thread down and have a whinge!
"Its not always about power, The car has to handle Beautifully" |
19-07-2010, 08:09 AM | #14 | |||
Hello Koni's!
26-07-2010, 09:51 PM | #15 | ||
Hi Russ, just a few questions: how did you find the service at Demon Tweeks? Also, is their postage insured and trackable?
I may consider ordering parts from them in the future, they seem to have reasonable prices. |
27-07-2010, 06:10 PM | #16 | |||
Hello Koni's!
Shipping - they do have tracking for international orders, and I'm 95% sure insurance is included as well, will confirm when my order is in stock. Overall, despite the few communication issues, happy with them so far.
27-07-2010, 08:38 PM | #17 | ||
Thanks Russ, please let me know if you encounter any more problems, I'd be interested to hear.
11-08-2010, 02:30 PM | #18 | ||
Hey guys,
im a new member to this site and find the info you guys give is awesome, i own a focus sedan 07 and was wondering what the cheapest option is to lower it, i dont want to go anything drastic, i just want to lose a bit of the gap between the tryes and the guard, heres a photo, hopefully iv put it on correctly. |
11-08-2010, 09:11 PM | #19 | ||
Hi Focuss, welcome to the forums.
King springs would be your best bet for an effective lowering option, that isn't too expensive. Just google their site for more details. |
12-08-2010, 04:56 PM | #20 | ||
Hello Koni's!
Nice wheels you have there.
Lovells are another option that aren't too expensive. Should be able to find them easily enough on day too.
12-08-2010, 05:09 PM | #21 | |||
Ones I'm looking at are all around 1200 pounds = $2200-2400AUD
GGR | SCT | Tein | Samco | Whiteline | Mongoose | Forge
12-08-2010, 07:12 PM | #22 | ||
The Bilstein B14 coilovers (height adjustable, fixed damping) are both around $1200 inc. shipping to Australia, from either European-Parts or Demon Tweeks. Just be careful with import taxes.
If you buy these, and save $1000, you owe me a beer! Although, at this stage, it looks like I'm now leaning towards the Koni Sport suspension kit, with adjustable Koni shocks + Koni lowering springs (35mm all round). |
11-10-2010, 10:49 PM | #23 | ||
Hello Koni's!
Something arrived last week...
Order took a LOT longer than expected...almost 3 months! Apparently Demon Tweeks had to order them from Koni in Holland. Would still have to pay at least $500 to buy the same thing in Oz, and thankfully I wasn't desperate for them. Thanks to DZ Ford (thanks Dan), I've decided to install these myself and just have an alignment done locally. Am ordering a Haynes manual to help out, but I have found a very good guide on changing the springs on XR5turbo.com - the steps are mostly the same. Can't wait to get them in, hopefully in the next few weeks. You pay a premium for this...
12-10-2010, 01:34 AM | #24 | |||
Good to see they arrived Russ, looking forward to seeing a review of how they perform!
