02-06-2010, 03:19 PM | #1 | ||
I'm getting a thud/knock which I can hear a feel through the floor when turning left or right. It is coming from the front left of the car. If I turn the wheel full lock to full lock at a standstill there is no sound it is fine. Will only do it when moving and there is some weight shift. Particulary noticable low-speed manouvering in car parks etc.
I also noticed if I take a fast brisk right turn at a round-about i can hear it go "thud-thud-thud" as more weight is shifted and then as the wheel returns to centre it will thud three times again as the weight is shifted off. Anyone had anything similar? Lower Ball joints are fine. Sick of throwing money at mechanics who do guess work replacing components until they fix it.
Formerly LV Focus XR5, AU Fairmont Ghia V8 & EBII Fairmont I6. Now...... 2012 FG MK2 XR6 Turbo - Manual & Luxury Pack - 302rwkw 2019 Escape St-Line |
02-06-2010, 08:00 PM | #2 | ||
When in doubt, GAS IT!!
how's the top bushes on your struts? Alternatively, check the wishbone bushes and swaybar bushes.
Bushbasher
03-06-2010, 11:45 AM | #3 | |||
By wishbone do you mean control arm?
03-06-2010, 06:42 PM | #4 | ||
adrian
I get a knock in my TS50 which sounds just like the knock ones gets when the IRS shock tower mounts are stuffed, is that what yours sounds like? and do the fronts also have a mount that needs replacing when this happens?
T3 TS50 #17 275kW AU3 XR8 SVP 220kW |
03-06-2010, 07:12 PM | #5 | |||
Bushbasher
06-06-2010, 12:25 AM | #6 | ||
The only thing u'll see!!
Tighten the front sway bar brackets on the chassis rail (T40 torque bit and 12mm spanner required). Tighten the front crossmember (18mm deep socket required and long lever bar x 4 bolts). Tighten main crossmember ( 18mm deep socket required and long lever bar x 4 bolts ). And last but not least tighten steering rack. ( 2x 18mm nuts) Good luck........
08-06-2010, 05:09 PM | #7 | |||||
08-06-2010, 09:34 PM | #8 | ||
My fairmont had clunks left right and center - bad enough to feel through the floor. Reco rack = no more clunks.
09-06-2010, 08:38 AM | #9 | ||
my au had similar problems, ended up being lower control arm bushes...
2016 fgx xr8, Black, Auto 2008 Lexus lx570, silver |
22-07-2010, 11:02 PM | #10 | |||
Was loose rack bolts.....
