Old 18-05-2010, 03:47 PM   #1
tick6vct
AU-XR-S3-VCT
tick6vct's Avatar
Default Removing seats in order to remove carpet?
Hi all
due to yet another rear wheel bearing issue my xr is confined in the garage until i can fund to fix it or arrange warrenty repair.
in the mean time seeing as its just sitting there i want to remove the carpet in order to do the audio install properly and also to try and clean a milk spill out thanks to a certain someone!
iv searched technical resources and had another search through the forums im eaither blind or theres not much info on this procedure. Before i do it myself anything i should know? apparently the back seat is very dificult to put back in? iv got time on my hands at the moment so i dont care if it takes a day or so to do
FOR SALE! AU S3 XR6 VCT | REBEL KIT | DEEP DISH 19'S | 275 WIDE REARS | CAT BACK | WHITEWALLS
tick6vct is offline   Reply With Quote Multi-Quote with this Post
Old 18-05-2010, 04:08 PM   #2
FGX335
Loving my '335' kW!
FGX335's Avatar
Nah, easy as. Just buy a Torx set, and you can remove seats, seat belts, etc. A few handy screwdrivers and you can take out the centre console and all of that stuff. Takes a little while, but works well. I removed the seats first, then the centre console, then the seat belt anchor point on the floor, and the scuff plates and trims near the doors. Take your time, it's great when you put it all back together again!
So in answer to your question, nothing out of the ordinary, and easy but time consuming.
FG X XR8 in Smoke. Smokin the tyres, that is!
XR8 logo pic taken at Avalon Airport, Falcon Fanatic filming 17th October 2014
FGX335 is offline   Reply With Quote Multi-Quote with this Post
Old 18-05-2010, 04:40 PM   #3
frd906
^^^^^^^ What he said, it is pretty easy to do, just take ya time
This is what i found under my carpet when i pulled it out
11 years of dirt and grim and suprise suprise no rust
Welder/Fabricator at Beaudesert Exhuast
Posted by Xcabbi, Does it slap or rattle? Rattle is more to do with timing chains and tensioners. Slap is more to do with lifters, rings, bearings or GENIII boat anchors
frd906 is offline   Reply With Quote Multi-Quote with this Post
Old 18-05-2010, 04:43 PM   #4
tick6vct
AU-XR-S3-VCT
tick6vct's Avatar
easy thanks fellas ill get stuck in tommorow arvo
Old 18-05-2010, 04:48 PM   #5
frd906
Now in the pic u can see a box in front of the tbar, now that was a pain in the *** to get the carpet out and back in, because beside the box is 2 brackets which hold the dash up
it was a huge pain getting the brackets bent out far enough to get the carpet out
So what i did was cut the old carpert down the middle of the Trans Tunnel, becuase with the console in place u wont see the huge cut and it was then easy enought to get it out around the box, brackets and the tbar
This enabled me to get the new carpert back in easyer as i did the same cut, along the Trans Tunnel section
Old 18-05-2010, 04:52 PM   #6
frd906
Also for got to mention, dont cut the carpet beyond the console it self lmao
Old 18-05-2010, 05:37 PM   #7
FGX335
Loving my '335' kW!
FGX335's Avatar
Oh yeah, forgot about the carpet. Yep, I had to cut it too, perfectly normal and you'll never see it anyway.
Old 18-05-2010, 08:39 PM   #8
adrian k
adrian
adrian k's Avatar
Originally Posted by fordbaghia
Just buy a Torx set
an allen key works just as well, can't remember what size, but it works a treat.
T3 TS50 #17 275kW
AU3 XR8 SVP 220kW
adrian k is offline   Reply With Quote Multi-Quote with this Post
Old 19-05-2010, 12:56 PM   #9
Cadge
I pulled out the interior of my car and replaced everything with leather and cleaner carpet. Took me about 7-8 hours, without rushing. I found having a drill with an attatchment made it so much easier than using a socket.
Did anyone else have to get those stupid star sockets? or is there another way to get the star bots out (ones holding seats and seatbelts down)
AUI Ford Fairmont | Lowered with Kings | XR8 Leather Interior | XR6 Tickford Engine and Gear box|
Cadge is offline   Reply With Quote Multi-Quote with this Post
Old 19-05-2010, 02:44 PM   #10
FGX335
Loving my '335' kW!
FGX335's Avatar
As adrian k said, you can use an allen key. But I recommend the torx set, I've used mine so many times since I bought them. Supercheap is where I got em, FYI.
