Old 16-05-2010, 06:20 PM   #1
snakefoot
T 140
Default oil leak au3
I have an oil leak in the front of the motor on my au3 2002. oil seems to be blown up onto the bottom of vct housing to give the appearance that the housing is at fault. have done the o-ring in the housing but still have the prob. just wonder if anyone can help cheers
snakefoot is offline   Reply With Quote Multi-Quote with this Post
Old 16-05-2010, 06:55 PM   #2
V8falcons
V8falcons's Avatar
The front main seal,can cause this as well. Pull the radiator,Crank pully,pop it out fit the new greased item in and away you go,and reseal the bolts around the timming cover as well.
T2 TE50 no:154 Narooma blue
AU2 XR8 ute
XR4 fiesta
V8falcons is offline   Reply With Quote Multi-Quote with this Post
Old 18-05-2010, 12:20 AM   #3
Mechan1k
Mechan1k's Avatar
Just the front ... or is it coming from the driver's side front top corner????
It's most likely coming from the cam chain tensioner ... and leaking onto the pulleys near there and spraying everywhere. Making it a pain to pin point.
