Old 11-05-2010, 08:27 PM   #1
private9
www.TUFFCARPARTS.com
private9's Avatar
Default Airbag light flashing repeatedly
Hi All,
Just purchased another AU as a work hack, and have noticed the airbag light flashing occasionally.
It does 1 flash, then pauses and does another 8 or so flashes after that.
Anyone know what this is and how to fix it?
Thanks,
Justin.
Old 11-05-2010, 08:46 PM   #2
falcontonner
just did a search and found this mate.
mine flashes 3 3 when its been sitting in the sun all day but if i turn it off ad back on it clears. any ideas anyone. never does it in the morning
falcontonner is offline   Reply With Quote Multi-Quote with this Post
Old 11-05-2010, 09:33 PM   #3
Mr Hardware
Flairs - Truckers Delight
Mr Hardware's Avatar
sort it out taxi style and just put some black electrical tape on the cluster glass over where the light is
NOT
was the car sold to you with a safety certificate/rwc and this fault present?
Old 11-05-2010, 09:34 PM   #4
private9
private9's Avatar
NOT
The thought did cross my mind, but I'd probably go a little more upmarket and pull the globe
Old 11-05-2010, 09:37 PM   #5
Mr Hardware
a man of distinction
Old 12-05-2010, 09:38 AM   #6
private9
private9's Avatar
An AU Forte column shift wagon will help you appreciate the finer things in life
Old 12-05-2010, 07:46 PM   #7
Ride
Stay Classy ™
Ride's Avatar
I had a similar problem recently but I'd get 4 flashes then 7. From doing research in the threads already posted in the forum the codes do change between the different series'. I believe 1 then 8 (18) is a Series 1 that has a fault with the drivers side pre-tensioner, either it's been activated or the plug is a bit loose. Mine was the passenger side that has already been activated and needed to replace it.
Ride is offline   Reply With Quote Multi-Quote with this Post
Old 12-05-2010, 08:06 PM   #8
private9
private9's Avatar
Thanks mate, I'll search a bit harder then!
It's a S2, and I might have got the number of flashes wrong. Will count it again properly next time I drive it.
Old 12-05-2010, 09:39 PM   #9
Mr Hardware
ahaha nice.
most unfalcon falcon i ever drove was a 98 EL wagon column shift hose-out interior with a bullbar. talk about riding the mechanical bull!
