Old 30-04-2010, 11:18 PM   #1
kcej
2mny projects 2 lttl time
Default AU3 front hub removal
I'm going to be removing my front hubs due to wheel bearing noise
I've read the GREAT how-to by ronwest, but one thing still bothers me
The hub nut with the strange (lock?) washer (that wraps around the nut) pictured below...(The bit I put RED LINES on)
Do you just use a socket that fits over the whole thing? or do you need to remove the outer casing pictured?
Also, is this nut re-usable, as in ronwest's pics it appears he has reinstalled the old nut with a new hub
any help appreciated thanks Keith
kcej is offline   Reply With Quote Multi-Quote with this Post
Old 01-05-2010, 12:16 AM   #2
ronwest
All Bran = Regular Member
Yep, socket goes over all of it. (edit - you know, I honestly can't remember if that's correct. You'll know for sure when you try to fit the 35mm socket).
I did in fact re-use the original nut with appropriate Loctite.
Old 01-05-2010, 01:01 AM   #3
kcej
Default Thanks Ron
Thanks Ron, GREAT How-to
Much appreciated
Keith
Old 01-05-2010, 07:42 AM   #4
Whoosha
AU DIE HARD
Whoosha's Avatar
Gees Ron I was thinking it was just me that looses the plot
its a 36mmsocket and yes it goes over the entire caseing and needs to be tightend to 305nm or realy realy tight ,my toque wrench doesn't even go that hi so just put a pipe over the breaker bar and lent on it Rons how to is spot on
Originally Posted by Riksta
Old 01-05-2010, 08:02 AM   #5
ronwest
Is it a 35mm or 36mm socket? I know the how-to says 36 but I miscalculated by one mm when I converted from imperial. I sent a correction in but I'm not sure if it was corrected.
Old 01-05-2010, 08:04 AM   #6
John@autObarn
CRANBOURNE
John@autObarn's Avatar
Whoosha brought a 36 off me to do his, and it didnt come back,so I guess it was the rite one
autObarn
CRANBOURNE
5995 7111
John@autObarn is offline   Reply With Quote Multi-Quote with this Post
Old 01-05-2010, 08:15 AM   #7
JC
JC's Avatar
I've got a 35mm socket and it worked for this too, so it looks like 35 or 36mm will work.
Ford Performance Club ACT
Old 01-05-2010, 08:23 AM   #8
ronwest
Yeah, I thought someone (couldn't remember who) had used a 35mm.
I recalculated the conversion and sure enough... ;)
Old 01-05-2010, 08:27 AM   #9
Whoosha
AU DIE HARD
Whoosha's Avatar
That's why i read your how to, I get a headache thinking and recalulating to much
Old 01-05-2010, 09:01 AM   #10
ronwest
What about your hairy mate?
I'd be leaving the technical detail to him...
Old 01-05-2010, 08:43 PM   #11
Jastel
Technical Contributor: For members who share their technical expertise. - Issue reason: Has much experience with taxis and always jumps on here to explain things simply and help out the new guys in B-series and Contemporary...
I use an Imperial size, an inch and something, from an old 3/4 drive set I had from my trucks, it works.
I have read you are supposed to replace and discard the nuts, similar to brake caliper bolts etc, each time you use them but I never have and neither has anyone else I know.
Do it up tight as you can with a decent size (2ft) bar, never had one come loose yet.
Jastel is offline   Reply With Quote Multi-Quote with this Post
Old 02-05-2010, 02:21 AM   #12
mik
mik's Avatar
on the other hand is it something you`d leave to chance? if i was going to reuse them i would wack a couple of drops of loctite on the thread.
