Old 19-04-2010, 09:20 PM   #1
SLO AU XR8
Default AU1 Brake upgrade question
I've been offered a BA Brake setup, and I was just wondering, is it worth putting it on my AU1? Also, can I use the BA Uprights on the front, and do BA sway bars and mounts work? Also, do BA rear brakes fit the AU IRS?
GT 335
11.3@124.1mph
383rwkw/513rwhp
Forced Performance Tuned
SLO AU XR8 is offline   Reply With Quote Multi-Quote with this Post
Old 22-04-2010, 07:48 AM   #2
Uncle_Ken
Next upgraded Mk1 Leopard
Uncle_Ken's Avatar
This thread has the AU1 to AUIII upgrade. Most guys have gone form AUII/III to BA.
I think if you do the AUI upgrade to AUII/III but use BA rotors and BD calipers it will work. Not sure about the rear brakes
http://fordforums.com.au/showthread.php?t=11244844
UK
Old 23-04-2010, 04:25 PM   #3
superroo
You can't stop the signal
superroo's Avatar
Rears will fit straight on to a degree. You will need to space the caliper out 2-3mm for them to sit correctly.
As for your other question, Yes to the uprights, Yes to the sway bar, and a 90% yes for the mounts
