Old 10-04-2010, 12:36 AM   #1
CRAIGAU3220
Cat be Still !!!
CRAIGAU3220's Avatar
Default 42LB Injectors, Where and what type.
Looking at a power upgrade for the 220 and will be in need of some 42LB injectors, so my question is where do i get them, how much should i pay and if i try too source them from the US of A what style/type do i need?
Thanks in advance, Craig.
CRAIGAU3220 is offline   Reply With Quote Multi-Quote with this Post
Old 10-04-2010, 09:43 AM   #2
terryk
When Only The Best WillDo
terryk's Avatar
Craig
Check these guys out
http://fuelinjectorconnection.com/sh...&productId=206
I bought a set of these injector for my 347 (32lbs), I had them within a week. They are brand new for under $400 AUS to my door. Great people to deal with.
Terry
terryk is offline   Reply With Quote Multi-Quote with this Post
Old 11-04-2010, 09:33 PM   #3
CRAIGAU3220
Cat be Still !!!
Thanks for the link terryk, Does any one know what type, I know lenght is 60mm oring too oring, is plug type EV6?
Old 12-04-2010, 03:37 AM   #4
veqlargh
Does upgrading your injector size mean that you will need a new flash tune? Or will the car run alright.
Weekend AUII xr8
Daily 1988 F250 460
Hers Eb xr8
veqlargh is offline   Reply With Quote Multi-Quote with this Post
Old 12-04-2010, 02:28 PM   #5
CRAIGAU3220
Cat be Still !!!
Yes will have to be retuned, Even if maf is calibrated to the same size injectors, will more often than not need a tune.
Old 13-04-2010, 07:38 PM   #6
XH5LWEPN
Boost is here!!
XH5LWEPN's Avatar
Yeah EV6 type are the ones your chasing.
You can actually fit EV1's if they are easier to find, which i think they are, you just need to get the adaptor plugs to suit.
These will be direct plug and play EV6's - http://cgi.ebay.com.au/BOSCH-968-42l...item27ad3e0cb0
Pretty good price too!!!
STREETBUILT RACING
'99 XHII XR8, 363w, GT4508R on 16psi, E85, C4, 910rwhp - ET coming soon!
'78 XC Falcon 500, Desert Gold, 351w, V2 on 16psi, E85, C4, 9" - 10.15@132mph!
XH5LWEPN is offline   Reply With Quote Multi-Quote with this Post
Old 13-04-2010, 07:40 PM   #7
XH5LWEPN
Boost is here!!
XH5LWEPN's Avatar
Sorry, they actually look to have the square EV1 type plug on them :S
They will fit, but adaptors will be required. Or you can modify your engine harness and cut off your current plugs and add E-series type ones.
STREETBUILT RACING
Old 13-04-2010, 07:57 PM   #8
xr8ute
Back on the road
xr8ute's Avatar
Are you prepared to buy second hand or must they be new?
The 2003/2004 SVT Cobra Mustang injectors are 39lb/hr at the std fuel reg, and 42lb/hr with the 220kw AU XR8 reg.
They are the same injector and connector type as the AU so they drop right in.
Old 13-04-2010, 08:46 PM   #9
CRAIGAU3220
Cat be Still !!!
Thanks for the info Jeff.
Would prefer new but may consider low mile used. Thanks for your input, I guess if i use your Mustang reference as a fitment guide i cant go wrong.
Cheers, Craig.
Old 13-04-2010, 10:40 PM   #10
terryk
terryk's Avatar
Craig
The one's I got have the same plug as the OEM units but as you can see they come with adaptors and they are also 60mm long as per the Bosch generation 3 (AU OEM).
Terry
Old 13-04-2010, 10:47 PM   #11
CRAIGAU3220
Cat be Still !!!
Sorry Terry have you attached a pic?
Old 14-04-2010, 12:27 AM   #12
CRAIGAU3220
Cat be Still !!!
I guess these are the puppys your talking about.
http://fuelinjectorconnection.com/sh...od&productId=8
Old 14-04-2010, 01:01 AM   #13
terryk
terryk's Avatar
Hi Craig
This is what I got, they are direct replacement injectors, hope this helps.
Terry
[/IMG]
Old 14-04-2010, 01:08 AM   #14
terryk
terryk's Avatar
This may be a better photos
Old 14-04-2010, 01:27 PM   #15
xr8ute
Back on the road
xr8ute's Avatar
Yep, thats them.
Old 14-04-2010, 08:11 PM   #16
CRAIGAU3220
Cat be Still !!!
OK, looks like Ive got it sussed. Thanks for your help fellas.
Hey Terry, looks like a stout build you have going there.
Old 14-04-2010, 09:34 PM   #17
terryk
terryk's Avatar
Thanks, it's getting there, I'm chasing a more suitable intake for it, the TFS street heat was ok for the 302 but not for the 347. The Photo below was taken in 2006 with the 5.0L
Old 15-04-2010, 12:57 AM   #18
CRAIGAU3220
Cat be Still !!!
May be step up to the Trackheat, Looks like you can buy the upper only.
http://www.trickflow.com/partdetail....t=TFS-515UB002
Old 15-04-2010, 11:10 AM   #19
RG
Back to Le Frenchy
RG's Avatar
Or he could buy a whole Track Heat from me.
Shameless aren't I lol.
Old 15-04-2010, 09:41 PM   #20
CRAIGAU3220
Cat be Still !!!
Are you a salesman Russ?
If not you should be.
Old 15-04-2010, 11:46 PM   #21
terryk
terryk's Avatar
Russ
Is that a track heat or a street heat, the runners seem a bit long for a Track heat, from what I can tell from the photos.
[IMG][/IMG]
Old 16-04-2010, 08:41 AM   #22
RG
Back to Le Frenchy
RG's Avatar
Looks like a track heat to me.
