24-01-2010, 08:47 AM | #1 | ||
My Fairlane when warm would sit between the N and O. recently i put in a new radiator and it seems to take a long time to warm up. i can drive for at least 10 minutes before it gets to the N and it now rarely gets to the O, even on 30+ days.
so question is - how long should it take? and is a lower temp good or bad? i was told if its not running at the right temp the ECU will make it run rich |
24-01-2010, 11:44 AM | #2 | ||
mine probably takes 10 minutes to warm up right through the metal, i`d have a guess though and say the thermostat opens up in probably half that time, so by 5 minutes it would be getting close to operating tempreture, i would`nt worry too much, it sounds pretty normal to me, unless it was staying substantially colder.
24-01-2010, 02:31 PM | #3 | ||
Might sound like an odd question but what would be bad about it being 'substantially colder' or taking longer than it should to warm up (e.g. thermostat stuck open)? What problems could/would it cause?
24-01-2010, 03:28 PM | #4 | ||
Sounds about right, my AU sits on the N on the temp.
Takes about the same time to get their. Your old radiator wouldn't have been working as efficient as your new one and hence probaly making the temp to climb quicker (less warm up time). Where did the temp sit before the new radiator went in? |
24-01-2010, 06:53 PM | #5 | ||
if it is too hot ,it will run rich and take out timing. the boss motor tuners acctually use termastats that run a bit cooler to gain power from the factory computer leaning out and adding timing. so my guess is you will use less fuel
24-01-2010, 07:00 PM | #6 | ||
I always let it warm up for a few miniutes if possible and i try to keep the revs down untill it reaches normal operating temperature.
24-01-2010, 09:59 PM | #7 | ||
i`m not sure what tempreture the cold start cut off is, but if memory serves me correct there was a post about this sometime ago and 170 c was deemed safe, 160 was too cold but don`t hold my word to gospel, i run a 170 degree thermostat in mine it made very little difference , the fans cut in at factory preset :( probably 190 /195 i`m guessing, running in cold start mode runs richer(uses more fuel).
24-01-2010, 10:08 PM | #8 | ||
Critical Thinker
I hear 82deg Celsius is the better thermostat to go for. Is this correct?
mik - from what your saying, the 170deg Fahrenheit/76deg Celsius is the lowest you advise before the cold start cutoff begins?
"Everybody was KungFu fighting..." 2022 Mazda CX5 GTSP Turbo 2024 Ford Everest Trend 1967 Ford XR FALCON 500 Cars previously owned: 2018 Hyundai Santa Fe Highlander 2021 Subaru Outback Sport 2018 Subaru XV-S 2012 Subaru Forester X 2007 Subaru Liberty GT 2001 AU2 75th Anniversary Futura 2001 Subaru GX wagon 1991 EB XR8 1977 XC Fairmont 1990 EA S Pak 1984 XE S Pak 1982 ZJ Fairlane 1983 XE Fairmont 1989 EA Falcon 1984 Datsun Bluebird Wagon 1975 Honda Civic |
25-01-2010, 08:59 PM | #9 | ||
82 C/ 180 F is the temp BPT motorsport have for their thermostats.
Power Stat they call it. Bought one but never fitted it. They reckon you get an extra 3kw's out of it, but yeah. |
25-01-2010, 11:23 PM | #10 | |||
27-01-2010, 10:52 AM | #11 | ||
Critical Thinker
thanks mik. I might just get the 170deg F one. I think I have a stock one at the moment.
