Old 17-01-2010, 10:03 AM   #1
auIILTD
5.6L x 2 pilot
auIILTD's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: For the effort put into the Australia day cruise to Albury Tech Writer: Recognition for the technical writers of AFF - Issue reason: AU Tech article.
Default AUII IRS rear sway bar replacement
Hi all. I am in the process of fitting my new whiteline swaybars to my LTD. I have managed to change the front on without drama, but I am having some difficulty physically removing the rear due to its shape an limited room to remove it.
Has anyone done this before? I am guessing I will have to disassemble the IRS unit in some way to be able to get the old one out and the new one in. I am just not sure what is the best way to approach this. Does anyone have some tips?
P.S. The front 30mm adjustable has made a massive difference - even on the softest setting.
2002 AU II LTD
5.6L 342ci T3 Short, AFR165 heads, Comp XE270HR-12 Cam, Brembo 4/4s(355/330), T3 5 spokes, LC-1 wideband, Whiteline HD swaybars, TCE 3K Hi Stall, PWR Auto Trans Cooler, Koni shocks, King Low Springs, Hurricane headers, 100 cpsi cats, Twin 2.5" exhaust.
Quarter Mile: 13.73 @ 105.86mph
Runner Up NA/DA to BF Fairlane/LTD Geelong AFD 2024
2002 XR8 pursuit 250
Custom twin 2.5" exhaust w Herrod modifed extractors, Tuned with Moates QH
auIILTD is online now   Reply With Quote Multi-Quote with this Post
Old 17-01-2010, 02:54 PM   #2
T3man
T3man's Avatar
You have to drop at least one of the rear half shafts out. Even then it requires a bit of juggling. If you take both out it is a piece of cake.
Old 17-01-2010, 03:09 PM   #3
auIILTD
5.6L x 2 pilot
auIILTD's Avatar
Cheers T3man. Being an AU and IRS newbie, are the half shafts much work? I have a Max Ellery workshop manual, but it does not say much apart from mentioning special tool number xxxxxxxx for the cv boot replacement.
2002 AU II LTD
Old 17-01-2010, 06:34 PM   #4
T3man
T3man's Avatar
You have to remove the wheel. Remove the strut. Remove the hub carrier. Then you can slip the shaft out of the diff.
