Old 02-11-2009, 11:52 AM   #1
AdzT3-146
own the road
AdzT3-146's Avatar
Default Moisture in headlight
G'day guys,
On the drivers side headlight on my TE50 i have a moisture problem with water seeping in there.
I haven't actually taken the headlight out yet but i would imagine there would be some sort of hairline crack somewhere around the light.
Just wondering if anyone else has a had a similar issue or if anyone can recommend somewhere in Melb who may be able to repair?
I have done a search and found lots of people recommend the headlight hospital, who I have already tried to contact via phone and email with no success, which is the main reason why I posted this.
Any help would be appreciated
Thanks,
Adam.
T3 TE50 #146
Originally Posted by UNR8D
Id rather date a goat with syphilous then drive a maloo.
AdzT3-146 is offline   Reply With Quote Multi-Quote with this Post
Old 02-11-2009, 01:31 PM   #2
Dave_Obsession
Resident AFF detailer
Dave_Obsession's Avatar
Pics?
Old 02-11-2009, 01:55 PM   #3
Uncle_Ken
Next upgraded Mk1 Leopard
Uncle_Ken's Avatar
If you need to pull it apart go here ofr the tech guide
Painting your headlight surrounds
http://www.fordforums.com.au/showth...ting+headlights
UK
Old 02-11-2009, 02:37 PM   #4
AdzT3-146
own the road
AdzT3-146's Avatar
I don't have any pics at the moment, i can take some when i get home after work..
Thanks for that UK.
T3 TE50 #146
Old 02-11-2009, 02:49 PM   #5
ch33z1l
Dawn
ch33z1l's Avatar
I put a little pit of silicon no caps around the joins in the headlight and haven't had any noticable moisture at all.
ch33z1l is offline   Reply With Quote Multi-Quote with this Post
Old 02-11-2009, 02:51 PM   #6
Uncle_Ken
Uncle_Ken's Avatar
Thanks for that UK.
No Probs. I'm doing mine at the moment. The glue is a bit tricky but not impossible. You might be able to cheat by putting a gel pack into the light (you know the type that comes with packaging to soak up mosture.
UK
Old 02-11-2009, 06:09 PM   #7
frd906
i had the same problem and just replaced mine, cost me 220 for a new set of headlights
Welder/Fabricator at Beaudesert Exhuast
Posted by Xcabbi, Does it slap or rattle? Rattle is more to do with timing chains and tensioners. Slap is more to do with lifters, rings, bearings or GENIII boat anchors
frd906 is offline   Reply With Quote Multi-Quote with this Post
Old 02-11-2009, 07:31 PM   #8
JC
JC's Avatar
That's cheap for a set, but fixing the old ones would have been cheaper.
If you go to Ford to buy a T series headlight, sit down before asking the price - they were around $800 each a few years ago.
Ford Performance Club ACT
Old 03-11-2009, 11:37 AM   #9
AdzT3-146
own the road
AdzT3-146's Avatar
Yeah, that's what I'm afraid of JC, i've heard the prices are astronomical for these things.
T3 TE50 #146
Old 04-11-2009, 03:32 PM   #10
POELWYK
Lost Boost Gained Class
POELWYK's Avatar
sounds like the boot in the back is not makeing a seal take them off and take the globs out and stick a hair dryer in there to dry the water out let them sit for about 1 hour then put them back togeather
2006 BF Fairmont Ghia
2001 AU Falcon
POELWYK is offline   Reply With Quote Multi-Quote with this Post
Old 04-11-2009, 04:00 PM   #11
Fev
Fev's Avatar
If it's not what Poel has suggested i'd reccomend pulling off the headlight. Pulling it apart (have to heat it up so the silastic stuff comes loose alowing you to pull it apart)
then clean off any water marks left inside the plastic shell, dry it all out. Pull off as much of the old silastic as possible, then re-glue it with new silastic making sure you create a good seal and then put it back together. Should be right after that.
Probably take you 3 hours
1992 EBII Fairmont Ghia 4.0l <---Click for the Gallery!
Insta@mooneye_ghia
White on bright red smoothies with thick whitewalls. Cruising around to some rockabilly
Fev is offline   Reply With Quote Multi-Quote with this Post
Old 25-04-2010, 01:34 PM   #12
Hords
Treasure your balls?
Hords's Avatar
Anyone know what sealant to use hear? Is it like the Shelley's Blaclk Windscreen Sealant?
Meteorite T3 TS50 ESS
Hords is offline   Reply With Quote Multi-Quote with this Post
Old 25-04-2010, 01:41 PM   #13
KR1STO
Just another mock-up..
KR1STO's Avatar
pretty sure that's what we used on my mates au...
gets all over your hands though...
how'd you go with the donuts btw....?haha
Desire isn't driven by the heart, the mind or the wallet.
Desire comes from another place.
It's created by the smell of burnt fuel under full throttle and the look a car gives you when you're washing it alone at night...
see my car here:
Built my own TL50!!!
[SIGPIC][/SIGPIC]
KR1STO is offline   Reply With Quote Multi-Quote with this Post
Old 25-04-2010, 02:10 PM   #14
Hords
Hords's Avatar
I felt sick after 7 :
The others got a mixed dozen, which would have been easier as all mine were filled. One of the guys finished first in 1˝hrs.
Old 25-04-2010, 07:15 PM   #15
frd906
i got the same problem now with my left hand side head light, mositure problem, also guys, where the indicator bulb fits in, u no how u got that peace of plastic in front of the bulb, is that spouse to move or spouse to be stuck there, as i can move it and maybe have found me problem
Old 26-04-2010, 10:29 AM   #16
KR1STO
KR1STO's Avatar
hahahaha...
jeebus he didn't muck around hey..!
see my car here:
[SIGPIC][/SIGPIC]
