Old 26-06-2009, 04:13 PM   #1
lofty
Rusticating
lofty's Avatar
Tech Writer: Recognition for the technical writers of AFF - Issue reason: Excellent article on AU Power window installation.
Default Preferred lifting methods
I just wondered what methods ppl use to access the underside of their AUs? I have 4 hardwood sleepers that I've cut into ramps so I can get about 5 inches of lift with the car level. I can then crawl underneath, but I'd really like more elbow room and clearance for a creeper. I'm considering investing in a trolley jack and a second pair of axle stands. Is it safe to get under a car on 4 axle stands? Is it safe to jack on the alloy front crossmember? Maybe with a block of wood?
PS: Just did a search on 'jack crossmember' and it seems it's one of those things that's risky but a lot a ppl do. (And expressly forbidden by Ford.) So let's not reopen that can of worms. Bit of a pain having to jack each side separately though...
Territory SYII RWD, BFII RTV tray
lofty is offline   Reply With Quote Multi-Quote with this Post
Old 26-06-2009, 04:29 PM   #2
au11futura
ROCKING THE EL FUTURA
au11futura's Avatar
car ramps mate.
i jack it with a troley jack then put the front on the ramps.
but if i need full acces to the rear i jack that on car ramps as well.
it pays to have four of them.
and two troley jacks.
BA MK11 XR8 ENFORCER NOW SADLY GONE
My build that was http://www.fordforums.com.au/showthread.php?t=11267696
ENVI BA XR6T
BUILD THREAD..http://www.fordforums.com.au/showthread.php?t=11345961 TAKEN BY THE EX
NOW A EL FUTURA
EB MONTY NOW IN THE SHED
BACK IN THE E-SERIES
THREAD DIGGEr
au11futura is offline   Reply With Quote Multi-Quote with this Post
Old 26-06-2009, 04:31 PM   #3
au11futura
au11futura's Avatar
to jack it from the front i put the jack on the cross member with a block of wood.
and the back i jack it from the diff.
ENVI BA XR6T
NOW A EL FUTURA
THREAD DIGGEr
Old 26-06-2009, 04:34 PM   #4
Hords
Treasure your balls?
Hords's Avatar
Don't do this if you have IRS.
Meteorite T3 TS50 ESS
Hords is offline   Reply With Quote Multi-Quote with this Post
Old 26-06-2009, 04:57 PM   #5
galaxy xr8
Giddy up.
galaxy xr8's Avatar
I have a BIG heavy duty trolley Jack and car stand's, they a built like a brick sh#*house,
I don't go cheap when safety is a major concern.
galaxy xr8 is online now   Reply With Quote Multi-Quote with this Post
Old 26-06-2009, 05:10 PM   #6
ronwest
All Bran = Regular Member
I bought a second 1900kg trolley jack a little while ago.
With two jacks, four stands + ramps I've just about got it covered.
Old 26-06-2009, 05:27 PM   #7
cjf
GT Hardcore
cjf's Avatar
Why ? because my tyre place did it to my BF GT when they were doing a puncture repair.
BF GT - 6spd ZF Auto - 292.8 rwkw 1/4 mile 13.385@ 108.32mph @ Willowbank 5/03/11. in Qualifiying STREET SERIES ROUND 7
http://www.fordforums.com.au/showthread.php?t=11295036
Cragsted Race Engines -http://cragsted.com.au/
BPR CAI , PACEMAKERS 4-1, BALLISTIC 100cell RACING CATS, CROW CAMS GTP,
K LINE , XFORCE ,PSI VALVE SPRINGS, MANLEY H BEAMS, SRP PISTONS & RINGS, ACL RACE BEARINGS MELLINGS BILLET OIL PUMP, POWERBOND UNDERDRIVES, TT1-160 THERMOSTAT.
cjf is offline   Reply With Quote Multi-Quote with this Post
Old 26-06-2009, 05:45 PM   #8
Hords
Hords's Avatar
Do a search with IRS + Jacking for more
Originally Posted by T3man
Yep, you can jack under the front alloy cross-member and under the diff on an XR8 with IRS. And with the money you save by doing your own services you can buy a new front cross-member when yours cracks, and new diff mounts when yours breaks, and get your tailshaft re-aligned and re-balanced because once the diff mount breaks the tailshaft will eventually bend due to misalignment and harmonic imbalance. You will probably have to do you own servicing for only about 3 years to save the money required for the above repairs.
Just jack under the car's correct jacking points and nothing will get harmed. You can place stands under the chassis rails at the front just near the jack points and same at the rear. At the rear you also can safely put stands under the lower trailing arms (as far to the rear as you can manage is best) if you have IRS. Naturally if you have a solid rear end you can jack under the diff and set your stands under the axle housings.
Old 26-06-2009, 05:56 PM   #9
au11futura
au11futura's Avatar
yeh no dont go by the diff if you have irs.
ENVI BA XR6T
NOW A EL FUTURA
THREAD DIGGEr
Old 26-06-2009, 05:57 PM   #10
galaxy xr8
Giddy up.
galaxy xr8's Avatar
Thank's for that mate, it will come in handy.
Old 26-06-2009, 09:10 PM   #11
mik
mik's Avatar
i have some railway sleepers also , gives me about 5/6 inches so i can get the 2t jack under, i also have a couple of bits of 30 x50 mm tube welded side by side approximatly 600 mm long with a keeper welded on one end so it can`t slide , it also has a piece of steel rod welded to the under side of it in the middle to locate it in the jack, i remove the lifting plate off the end of the jack and sit the steel paralel to the jack and use the alloy x member and front steel x member......it looks a little ugly but its effective , it gets the car up about 600mm to sit on 3 ton stands and shares the load on 2 x members.
Old 27-06-2009, 01:26 AM   #12
JC
JC's Avatar
I use the front cross member, but you have to have the jack towards the back of it or it slips off (guess how i found that out????).
Also, you can jack on IRS rear using the cradle, which is just behind and above the diff.
Ford Performance Club ACT
Old 27-06-2009, 10:13 AM   #13
lofty
Rusticating
lofty's Avatar
Originally Posted by mik
a couple of bits of 30 x50 mm tube welded side by side approximatly 600 mm long <snip> use the alloy x member and front steel x member...<snip> shares the load on 2 x members.
Mik, i like your thinking. I'm guessing the tubes are oriented vertically?
Another option I was considering is the display ramps car yards use, like this: (ebay link) My concern is that with no height adjustment, you could end up at the wrong height for some tasks and be no better off. For the price though I'd buy 'em if they were in my state.
Old 27-06-2009, 11:36 AM   #14
mik
mik's Avatar
yes the tubes run inline with the engine , should you do this you need a keeper because its on a slight angle and metal on metal is slippery, but it works quite well as long as your on sleepers or already up a bit off the ground, nice ramps in the link .... if you can get them for the right price would be very handy, agreed on the wrong height at times, but for a lot of jobs or quick inspection under the whole car it would be great i think.
Old 27-06-2009, 01:00 PM   #15
Bolly
Bolly's Avatar
Which is the best way to lift the rear of my XR safely????
I looked at the front end and noticed its made of alloy.. is it even safe to use the trolly jag to lift the front...????????
I want to adjust the hanbrake cable and have a good look underneath the car...
Help!!!!
Bolly is offline   Reply With Quote Multi-Quote with this Post
Old 27-06-2009, 08:36 PM   #16
JC
JC's Avatar
Help!!!!
Take a look at post #12. I assume you'd use jack stands as well.
Old 28-06-2009, 06:45 AM   #17
Cookie-XR8
SKID IT
Cookie-XR8's Avatar
my jack pulls it up high and have big jack stands, not little supercheap ones, brings it about a foot from the ground when the stands are on the lowest point
Style, Create Your Own
BF XR6T Ute - 422rwhp tuned by FPT Toowoomba
Where the boost junkies hang out -Forced Ford Forums
Cookie-XR8 is offline   Reply With Quote Multi-Quote with this Post
Old 28-06-2009, 08:57 PM   #18
dusty86
a hoist
2009 FG turbo ute
1983 Toyota sprinter- quick/fun car with a Nissan heart
2010 CRF250- when I want to get dirty
dusty86 is offline   Reply With Quote Multi-Quote with this Post
Old 29-06-2009, 04:08 AM   #19
Bolly
Bolly's Avatar
Not a bad idea Dusty86...
That way i can have a good look the best way to jack the car up..
Old 29-06-2009, 12:39 PM   #20
lofty
Rusticating
lofty's Avatar
Originally Posted by dusty86
a hoist
If you have one, please show & tell. And tell us your address
Old 30-06-2009, 02:07 PM   #21
dusty86
workshop and pretty relaxed boss
2009 FG turbo ute
Old 30-06-2009, 03:17 PM   #22
ebxr82nv
Help!!!!
You adjust your handbrake inside the rear wheel hubs not by the cable, don't ask me how but cause I haven't had to do mine yet.
9/98 AU1 XR6hp-about to retire from the road and be reborn on the race track.
86 ZL mint grandpa spec with premo sound and 150000km
07 TTG XForce, PLAZMAMAN, IDYNO TUNED, 349KW@all 4!
97 el futura MOCKed up with a 2500 stall, heaps of fun!
ebxr82nv is offline   Reply With Quote Multi-Quote with this Post
