Old 24-06-2009, 02:43 PM   #1
au11futura
ROCKING THE EL FUTURA
au11futura's Avatar
Default Mounting pioneer in futura.
hey guys i need some advise in mounting my deck into my console.
ive got a pioneer unit, but as the au deck is different i cant find a solution as to mounting my deck.
i saw a write up somewere on the forum on how mount it but i cant seem to locate it now and i realy want to get this done.
ohh im not paying any one to do it as im not tottaly useless, and ive still to pass all my amp wirering through.
thanks for helping.
BA MK11 XR8 ENFORCER NOW SADLY GONE
My build that was http://www.fordforums.com.au/showthread.php?t=11267696
ENVI BA XR6T
BUILD THREAD..http://www.fordforums.com.au/showthread.php?t=11345961 TAKEN BY THE EX
NOW A EL FUTURA
EB MONTY NOW IN THE SHED
BACK IN THE E-SERIES
THREAD DIGGEr
au11futura is offline   Reply With Quote Multi-Quote with this Post
Old 24-06-2009, 03:02 PM   #2
whiskers
gone fishing
whiskers's Avatar
you may be looking for this.........
http://www.fordforums.com.au/showpos...&postcount=123
Whiskers
whiskers is offline   Reply With Quote Multi-Quote with this Post
Old 24-06-2009, 04:04 PM   #3
Dave_Obsession
Resident AFF detailer
Dave_Obsession's Avatar
is your unit double-din or single-din?
If it's single-din, you will need to buy a pocket to sit underneath the pioneer unit.
You can buy them from JB etc for $20.
So it will look like this:
Old 24-06-2009, 06:03 PM   #4
au11futura
au11futura's Avatar
yeh i got the pocket. thanks guys
ENVI BA XR6T
NOW A EL FUTURA
THREAD DIGGEr
Old 24-06-2009, 06:07 PM   #5
au11futura
au11futura's Avatar
na not it the one i saw showed how brackets were made to hold the deck in as there is a small space between the pocket and the deck.
ENVI BA XR6T
NOW A EL FUTURA
THREAD DIGGEr
Old 25-06-2009, 09:13 AM   #6
au11futura
au11futura's Avatar
any one with any suggestions i still cant find that thread....
ENVI BA XR6T
NOW A EL FUTURA
THREAD DIGGEr
Old 25-06-2009, 12:48 PM   #7
75van
Van Mad
75van's Avatar
Here's a good one:
http://www.fordforums.com.au/showthr...=single+pocket
I did the same thing when installing my Pioneer unit, except I didn't make the steel strap under the cradle like NC1183 did. You need to drill some holes in the side of the cradle to allow you to bolt the surround back in after you've put the cradle in.
I found that the cradle will sit there fine without the steel strap if you install the cradle first, then bolt the surround back into position, slide the head unit into the cradle (while making sure the rear retaining screw and rubber poke into the factory hole), then instal the pocket underneath. If you put the pocket in before the headunit it makes it pretty hard to line up the screw and rubber.
The new wheels: 1975 Ford Escort panelvan. Build blog here.
75van is offline   Reply With Quote Multi-Quote with this Post
Old 25-06-2009, 01:08 PM   #8
grandpa_spec_F6
AFF Whore
grandpa_spec_F6's Avatar
I was lazy, got the pocket and put it in, then used some sticky foam strips along the top and underside of the front of the headunit, wedged it into place, hasnt fallen out since and looks fine =D
grandpa_spec_F6 is offline   Reply With Quote Multi-Quote with this Post
Old 25-06-2009, 10:28 PM   #9
NC1183
NC1183's Avatar
Originally Posted by monkeysxr6
Here's a good one:
I put the strap underneath because i've got my headunit sitting out a bit at the front, to level up with the pocket and front of the dash. Also gives the headunit cage another place to clip too.
Nathan
2005 FPV BF Super Pursuit
The new toy (now sold)
The SP
The old ute (sold)
www.aufalcon.com/nc1183
Build Thread
Originally Posted by F6T
If you look closely you can see the remains of a Hyundai excel that’s been sucked into the intake.
about the pic of 'CHOP YA' F6
NC1183 is offline   Reply With Quote Multi-Quote with this Post
Old 26-06-2009, 04:24 PM   #10
au11futura
au11futura's Avatar
ahhhhhhhhhhhhhh thats it thats the one thanks heaps mate ohh greatest day of my stereo fitting life. lol again thanks heaps.
ENVI BA XR6T
NOW A EL FUTURA
THREAD DIGGEr
Old 26-06-2009, 08:50 PM   #11
bo0
bo0's Avatar
i installed an alpine deck to my AU a few weeks back, I did a similar thing to the strap method...
bent two pieces of metal into an L shape, and welded them to the HU cage. then had screws from the L brackets into the metal dash sides.
More effort, I know : but its sturdy as and won't be ripped out in a hurry!
havent put in the din pocket so theres a big hole there , but its rough plastic and looks crappy (bought it off ebay, what do you expect).
What brand makes the plastic like the dash texture??
The Beast:
'05 E60 BMW M5 - 5L V10 Goodness!
Daily/Project:
'92 EBII Fairmont 5L Build
Old Rides:
'01 AUII XR6
'97 EL GLi
'90 EA S-Pack
bo0 is offline   Reply With Quote Multi-Quote with this Post
