25-03-2009, 01:04 PM | #1 | ||
i hav fitted a new stereo into my car and also used 1 of those pockets to go under as well, but it doesnt seen to sit right and is moving around and its also sitting about 1cm in aswell. Is there any i havent mounted correctly?
25-03-2009, 01:43 PM | #2 | ||
If you bend a few of the tabs on the cage you should be able to get it to sit a little straighter. It might still move a little bit if you don't fasten it with screws but I managed to get rid of most of the movement by bending the cage tabs.
The pocket should be sitting flush with the rest of the console. It's just a matter of fiddling around with the cage and pocket. By the looks of it, the plastic tabs on the pocket are hitting the lip of the cage. As for the gap between the head unit and pocket, you can try and hide it a little more by straightening out the head unit a little more or perhaps bringing it forward a little. Other than that, you'll have to make a custom surround out of MDF or similar to fill out the space properly. There are a couple of threads on here that go into it. I was going to attempt making one myself but the look of it doesn't bother me too much. This is one of my pet hates with the AU2/3. They improved the look of it over the AU1 but stuffed up the 'flushness' due to the curve if you decided to go single din. |
25-03-2009, 02:19 PM | #3 | ||
might look into the MDF space and i might make a couple of brackets up and remove the cage all together
25-03-2009, 02:38 PM | #4 | ||
Sounds good. Try and find those threads I mentioned. They should give you a few ideas
25-03-2009, 05:29 PM | #5 | |||
25-03-2009, 06:13 PM | #6 | |||
This thread Headunit Info has some really good info in it, including pics of mine.
Nathan 2005 FPV BF Super Pursuit The new toy (now sold) The SP The old ute (sold) www.aufalcon.com/nc1183 Build Thread Quote:
25-03-2009, 08:59 PM | #7 | ||
Flairs - Truckers Delight
you know whats worse than that pos install job
manual in an au
25-03-2009, 09:03 PM | #8 | ||||
Who you talking to. Also, keep comments like that to yourself, at least he had a go, put up what he tired, and asked for help fixing it.
26-03-2009, 12:57 AM | #9 | |||
29-03-2009, 10:35 PM | #10 | ||
Now with an AU XR6
One of the best ways i find to mount H/U's in an AU is to rivet the cradle into the plastic surrounding it. Just find a position where you are happy with the look and bobs your uncle.
Stop chasing me! I don't have any donuts! 1999 AU1 XR6 VCT - Now with a momo steering wheel! Manual - 18" Koya Race Tek's Black with polished lip - Lowered - Series 2 tail lights - Pioneer P80 Head Unit - Clarion Front 6" Splits - JL 5x7's Rear Coaxials - Clarion 4x90w RMS amp - Clarion DPX1800 800w RMS mono - 2 Clarion PXW1251 400w RMS 12" subs Team Deck Chair Member ............ Once you sit down, you'll never stand up. |
30-03-2009, 12:43 PM | #11 | ||
On this topic but taking a slightly different tack, has anyone ever tried mounting the head unit in the lower position with a pocket or panel above it?
I'm considering a place to mount a couple of gauges without cutting into the car... I'm thinking that a custom panel with an aftermarket head unit mounted at the bottom would be ideal. As for your comments MR HARDWARE... Stick to your ex-taxi's. |
