Old 15-01-2009, 07:09 PM   #1
Mr Cube
Mr Cube's Avatar
Default No oil pressure
Driving home today, I noticed a hissing sound coming from the front end, and tapping..
Anyways quickly pulled over popped the hood, I have got oil in the engine, its clean, not losiing oil anywhere. The tapping appears to be the fact there is no oil getting to the engine... The car is not overheating either...
Any ideas on what it may be and cost to fix it up?
Quick look in the gregorys, might be the oil filter blocked, but not sure if that sounds right.. Rekon it may be the oil pump, never had one go so wouldn't have a clue.. Any ideas would be appreciated...
Have you got an FPV or XR6/8 and live in the ACT or surrounding area? Come and check out the FPV & XR Owners Club of ACT
AUI VCT:
To date - Big brake upgrade, Koni and Kings all round, 2.5 cat back ready for replacing, 19" again ready for replacing.
Planned - Too much now I got the baby back.
Mr Cube is offline   Reply With Quote Multi-Quote with this Post
Old 15-01-2009, 10:25 PM   #2
Papa Smurf
Papa Smurf's Avatar
Maybe the Lifters? might be sticking.
Papa Smurf is offline   Reply With Quote Multi-Quote with this Post
Old 16-01-2009, 12:42 AM   #3
Mechan1k
Mechan1k's Avatar
Over time the lifters can get gunked up ... and they get jammed ... causing the ticking (or sometimes a loud clacking) ... in turn cause a slightly rougher idle due to this as well ... something to do with the valve not closing fully and vacuum is out.
I had it occur on the odd occasion ... but it'd go away when it cleared out ... but i knew one was on it's way out ... to replace them all there's 12 of them ... and can be anywhere from $10-$20 a pop (depending where you purchase them).
Old 16-01-2009, 06:39 PM   #4
Mr Cube
Mr Cube's Avatar
Thanks for the tips, Im hoping that it isn't anything too major.. One mechanic said it may be the oil pump, which meant taking the engine out to replace or service, not sure what they recommend there,,,
If the lifters are shot would it be something that just goes and you notice it, and would it result in no oil pressure?
AUI VCT:
Old 17-01-2009, 08:58 AM   #5
Mechan1k
Mechan1k's Avatar
Yeah ... lifters can just go ... something it might just get gunk in them and jam up.
I'd check them first ... cheaper and easier than an oil pump.
It is east to tell if it is a lifter ... the sounds can be quite loud .. and from the rocker cover area (usually rear ones go first though). Lifter won't result in no oil pressure ... just a vacuum drop causing a slightly rougher idle.
A stuffed oil pump would result in no oil pressure though.
