Old 09-11-2008, 01:49 PM   #1
GS608
Default beeping
on start up i noticed that the car does 11 sets of 3 beeps, theres no light on the cluster to tell me somethings wrong so i have no idea what this could be?
any help? should i take it to a Ford dealer and get them to look at it?
Old 09-11-2008, 02:18 PM   #2
Bushbasher
When in doubt, GAS IT!!
Bushbasher's Avatar
Are you sure it's not just the low fuel warning which goes off at 80km to empty?
MINE- AUII Forte
Old 09-11-2008, 02:25 PM   #3
Whoosha
AU DIE HARD
Whoosha's Avatar
3 beep warnings are usually fuel related 80ks 60 40 20 to empty
3 beep is also for ajar door or faulty sensor usually at start up
5 beeps is oil related pressure or sender
5 is also cooling system related .from low water to overheat to faulty sensor
3 to 5 can also be ABS or seat belt pretension conections check under your seats for loose fittings
most have a coresponing warning light on the dash (if they all work,)
failing the usual checks you may need to Ford to scan it for codes
Originally Posted by Riksta
Old 09-11-2008, 03:34 PM   #4
GS608
thanks woosh, its not fuel related as its got a full tank of juice
might be door ajar but when i close the door it still continues for a few more sets of 3
Old 10-11-2008, 07:41 AM   #5
Mechan1k
Mechan1k's Avatar
Is it auto???
If stationary ... and in Park .... so the speedo needle spike up a bit with the handbrake on???? If this does happen ... it usually the speed sender in the side of the auto ... car thinks it is moving while the handbrake is on .. just another thought.
