Old 03-11-2008, 11:59 PM   #1
sooty43
Default noisey au wagon
My au wagon 1999 mod. is a lot more noisier than the xf wagon work vehicle. It is interior noise not exhaust. Would fairmont interior be a fix? or are there other methods? Maybe a whole new set of suspension rubbers?
sooty43 is offline   Reply With Quote Multi-Quote with this Post
Old 04-11-2008, 12:02 AM   #2
rag top
rag top's Avatar
Tyres causing the noise?
rag top is offline   Reply With Quote Multi-Quote with this Post
Old 04-11-2008, 07:02 AM   #3
au2sw
Blown 5L coming
au2sw's Avatar
what sort of noise? i asssume its from the dash due to your question about monty dash upgrade. is it squeaking from the dash? if so theres a couple of causes of this, one is the center dash facia where the radio sits, the panel rubs on the rest of the dash in some spots. another one i found was the directional air vents in the dash. mine occasionally rattle and squeak in the housing. not really much you can do about either AFAIK, there may be some1 here who has solved the problem though, as it is common. all most of us do though is just crank the tunes....never here the noises then
1995 EF Fairmont was stocko 6cyl with open single spin diff....NOW WITH XR8 ENGINE, DRIVELINE AND SUSPENSION!!!!! Maybe by the end of 2010 there may just be a blower as well ;)
NEW CLUB FOR SUNSHINE COAST !! www.f-p-e.proboards.com
Contact Col (au2sw) via PM or on MSN @ efmonty@hotmail.com
Originally Posted by Mr Hardware
Its like central locking in your car. We've all had cars without it and we were fine then, but try and take it from me? NO WAY.
au2sw is offline   Reply With Quote Multi-Quote with this Post
Old 04-11-2008, 10:08 AM   #4
private9
www.TUFFCARPARTS.com
private9's Avatar
If it's just a general sorta road noise, it could be stuffed tyres (feathered etc) or even wheel bearings. I've had a few cars that have worn out the wheel bearings, and they get damn loud towards the end!
Old 05-11-2008, 10:06 AM   #5
sooty43
Its road noise, BTW all my tyres and bearings are OK. Could it be lack of sound deadening in the body panels and bonnet and roof?
Old 05-11-2008, 10:36 AM   #6
rag top
rag top's Avatar
What brand of tyres are they??
Old 05-11-2008, 11:35 AM   #7
GK
Walking with God
GK's Avatar
I've fixed such squeaks with a spray of silicone spray on the hinges / plastic pins. It's been over a year and they've not returned. Apparently that's all Ford do if people have concerns.
Another helpful forum member gave us the helpful tip a few years ago, but I can't remember who it was.
Cheers,
GK
Now gone!
On LPG
Want a Full Life? John 10:10
Old 05-11-2008, 06:36 PM   #8
private9
private9's Avatar
Something is definitely wrong. I've had a few AU's, plenty of XF's and a squillion of the abortions in between, and there is no way that all being well that an XF is quieter than an AU.
Tyres in particular can still look good, but some as they wear down just get very noisy, or maybe they've feathered or worn badly causing some noise.
I would look very closely again at tyres and wheel bearings. Both will cause extra road noise.
Old 06-11-2008, 12:18 AM   #9
sooty43
The tyres are firestone. I willput the car on the jack tomorrow and spin up the front wheels with a starter motor that I use for my vintage racing motorbike and find if the bearings are OK.
Old 06-11-2008, 05:34 AM   #10
rag top
rag top's Avatar
Also check the diff fluid level/condition
Old 09-11-2008, 03:40 PM   #11
sooty43
I have spun the the wheels and there is no bearing noise. the diff. is also quiet. the tyres are Goodyear GA plus and it is definately tyre noise inside the wagon. Is the brand of tyres the problem or is the lack of insulation in the car body? All sugestions taken on board.
Old 09-11-2008, 05:19 PM   #12
waggaclint
waggaclint's Avatar
you will find that the wagons have more road noise than a sedan because the back it more open....if your tyres/bearings etc are ok you could always put some sound deadening under the carpet and in doors etc...ive been looking at doing this to mine but havnt got around it yet.....
waggaclint is offline   Reply With Quote Multi-Quote with this Post
