Old 29-09-2008, 07:58 AM   #1
sleekism
1999 Ford Fairmont Ghia
sleekism's Avatar
Default Headlights not working WTF???
My headlights both highbeam and low beam are no longer working. It doesn't even display the highbeam light on the dash anymore. My parkers work though.
As well as that my A/C is no longer working.
As the A/C and headlight fuses are next to each other I'm thinking fuses but how do I check the fuses thay are solid and coloured?
sleekism is offline   Reply With Quote Multi-Quote with this Post
Old 29-09-2008, 08:24 AM   #2
whiskers
gone fishing
whiskers's Avatar
you might need to see if one of the bulbs have blown for the high/low beam as this could stop the other one from working, as for the air con check the gas maybe other than that a trip to a auto elec might be in order.
Whiskers
whiskers is offline   Reply With Quote Multi-Quote with this Post
Old 29-09-2008, 09:09 AM   #3
Windsor220
Now Fordless
Windsor220's Avatar
You can check fuses visually. They are usually see through and you can see if the metal part has broken.
If its a relay, try putting a relay from another part of the car in there and testing it.
Old 29-09-2008, 09:18 AM   #4
RG
Back to Le Frenchy
RG's Avatar
You also had the ABS problem didn't you? Did that get sorted, if not I think you may have some pretty bad electrical dramas going on that would be causing all of this.
Old 29-09-2008, 05:41 PM   #5
brad`
The Monty
brad`'s Avatar
called "ghost in the machine"
brad` is offline   Reply With Quote Multi-Quote with this Post
Old 30-09-2008, 01:06 PM   #6
sleekism
sleekism's Avatar
I fixed the problem. Apparently the headlights are wired through the ABS fuse so a new ABS fuse got them working perfectly again.
Old 30-09-2008, 01:35 PM   #7
Mr Hardware
Flairs - Truckers Delight
Mr Hardware's Avatar
glad to hear you got it fixed, sleek the elite.
negatory.
