Old 14-09-2008, 07:54 PM   #1
Rodco
Default Ticking/clicking noise from rear end
Hi all -
I've got an AU1 Fairmont Ghia V8 - has a noticeable noise that seems to come from the the rrear end - very noticeable at low speeds - been the same for 12 months or more - noise now seems to be getting more pronounced. Just completed a trip to Perth and back, no problems. (Had to put another new radiator in - standard industry warranty is 3 to 5 years - Ford warranty 12 months!!!) Anyone had a similar noise? Have spent hours under the car and cannot find the noise.
Rodco is offline   Reply With Quote Multi-Quote with this Post
Old 14-09-2008, 08:28 PM   #2
howesy
howesy's Avatar
sometimes a noise such as this can be associated with worn universal joint or centre bearing issues on 2 piece shafts. might be worth a check as its something simple and cost F@*% all. Take it to someone and get it up on a hoist in gear running. If the noise increases with speed it has to be drivetrain or wheel related.
Can't beat a Windsor for sound and low down torque.
Liquid Silver Pursuit250
Custom gear and diff ratios
ECU
Exhaust
Crow Comp. Valve springs
Adjust. Rollers
Cold air
howesy is offline   Reply With Quote Multi-Quote with this Post
Old 15-09-2008, 02:00 PM   #3
Dauphin
Irregular member
Dauphin's Avatar
My car did that for a few weeks and then it went away by itself one day. I had the car raised and in gear and it wouldn't do it. Put it back on the road and it did, so I never got to the bottom of it. All tyres checked for screws / rocks and they were fine.
Old 15-09-2008, 02:03 PM   #4
JoesAu
JoesAu's Avatar
check your rear brake pads aren't moving in the caliper, as my car was making a noticably loud clickin-ticking noise until i glued the bastards in which fixed the noise.
JoesAu is offline   Reply With Quote Multi-Quote with this Post
