Old 19-07-2008, 06:49 PM   #1
Clarke AV
OzECruisers Treasurer
Clarke AV's Avatar
Default Advice On The Right Slicks To Put On My Car
I am currently looking at purchasing some Mickey Thompson racing slicks. size 26 x 8.5 x 15. Now, will they work on a 7" rim, which I think most standard Ford rims are in width? Is there much difference between putting them on alloy or steel? Or what size should I put on a stationwagon that develops 150kW at the wheels - only on a good day? I've just purchased a LSD centre and I would also like some advice on what ratio before I get it installed. The car is a work car so I don't want to go too high with today's fuel costs and I basically love going to the track, but it's once every 6 months only. And I have absolute fun, even though I don't have a fast car. But I would like to at least wipe 1 second off my current time, hence the slicks, and I don't want to buy the wrong thing.
Any other advice would be most welcome. I've attached 2 links below.
Yes that one was a bad reaction time, I normally average half a second.
http://members.optusnet.com.au/~bccl...08/233-264.avi
http://members.optusnet.com.au/~bccl...8/233-burn.avi
One last question: how much of a burn-out warm-up is required and how many runs would I get out of them? Thank you very much for reading my post.
Clarke AV is offline   Reply With Quote Multi-Quote with this Post
Old 19-07-2008, 07:48 PM   #2
ClevoCapri
ClevoCapri's Avatar
Hello. They will certainly work on a 7 inch rim. Your diff ratio realy depends what you want to do with the car. I feel a 3.7 is a good ratio that you can still drive around on daily but wakes the car up a heap. Unless you can rev your engine alot harder than stock there isnt much point going to say 4.11's. They would probably slow you down!
They dont need much of a burnout at all. I have made around 30 passes on slicks before they were abit too low on tread. Thats not with small burnouts all the time though!
Brett
ClevoCapri is offline   Reply With Quote Multi-Quote with this Post
Old 20-07-2008, 12:06 AM   #3
xdclevo
The Fun Mobile
xdclevo's Avatar
A set of 235/60/15 MT ET streets would have worked a treat too.
They will hook hard, so watch it pulling down too low in the revs on
take off if its a manual.
408 cube Cleveland
TFC @ AFD 2V, 750 DP
10.7 @ 125 mph
2V powahhhhh
xdclevo is offline   Reply With Quote Multi-Quote with this Post
Old 23-07-2008, 09:41 AM   #4
jcxr
Tribal Elder
jcxr's Avatar
The relatively narrow rim can also allow lower tyre pressure to be used to get a wider rubber " patch" for traction. This is still an over kill if you havent the power to be able to use it. Are you having traction issues???
jcxr is offline   Reply With Quote Multi-Quote with this Post
Old 23-07-2008, 10:37 AM   #5
paddy351
Ford Nut
paddy351's Avatar
What front tyres are you going to use ? as full slicks need front runners. If you run your normal fronts look for slick radials.
Clevo + toploader = :
paddy351 is offline   Reply With Quote Multi-Quote with this Post
Old 23-07-2008, 11:03 AM   #6
jcxr
Tribal Elder
jcxr's Avatar
For front runners, use conventional,not radial ply tyres if using slicks. Dont mix radials and conventional tyres ever.
Old 23-07-2008, 03:03 PM   #7
Bluepower
KenneBell Australia
Bluepower's Avatar
150rwkw may not be enough to get a full benefit from a slick tyre.
Bluepower Racing Developments
Proud Australian Distributors of Kenne Bell superchargers
The Quickest, The Fastest, The Baddest Boss Blower of all.
www.bluepower.com.au
Bluepower is offline   Reply With Quote Multi-Quote with this Post
Old 23-07-2008, 04:33 PM   #8
nugget378
Weezland
nugget378's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: Always willing to impart knowledge in the technical areas.
Just buy some et radials and run them at higher pressures with your usual front tyres,as mentioned you cant run these without a crossply frontrunner,
these slicks will slow you down I think...
nugget378 is offline   Reply With Quote Multi-Quote with this Post
Old 23-07-2008, 07:28 PM   #9
Clarke AV
Clarke AV's Avatar
Thanks for the advice. I think i'll just go with the et radials and see what it's like with the LSD diff.
Old 23-07-2008, 08:11 PM   #10
ClevoCapri
ClevoCapri's Avatar
You can run slicks with radial fronts until an et of 12.99 I belive.
