Old 01-07-2008, 11:21 AM   #1
Mont5.0
Mont5.0's Avatar
Default Ba-AU Seats
Is it possible to put BA into AU front seats without to many drama's? Anybody done this?
FGII XR6 IN LIGHTNING STRIKE
R52 SIII IN GUN METALLIC
Mont5.0 is offline   Reply With Quote Multi-Quote with this Post
Old 01-07-2008, 12:06 PM   #2
brad`
The Monty
brad`'s Avatar
i was wondering in the same, also if you can put back seats in aswell
brad` is offline   Reply With Quote Multi-Quote with this Post
Old 01-07-2008, 12:13 PM   #3
ON_DUBS
[ON DUBS]
ON_DUBS's Avatar
I've tried it.
Front is easy, rear is not possible due to the difference in design.
BUT i tried it in my fairlane. If the fairlane rear seat is exactly the same shape as falcon based models then no you won't fit a BA seat in.
ON_DUBS is offline   Reply With Quote Multi-Quote with this Post
Old 01-07-2008, 02:31 PM   #4
b2tf
not here much anymore
b2tf's Avatar
Fairlane rear seat is wider
This can be done but you need to have the rails changed so the BA seat is on AU rails
2024 F150 XLT
Old 01-07-2008, 02:48 PM   #5
RG
Back to Le Frenchy
RG's Avatar
But is that a direct bolt over or a welder job?
Old 01-07-2008, 02:49 PM   #6
NC1183
NC1183's Avatar
So is it possible to swap the rails straight over between seats
Nathan
2005 FPV BF Super Pursuit
The new toy (now sold)
The SP
The old ute (sold)
www.aufalcon.com/nc1183
Build Thread
Originally Posted by F6T
If you look closely you can see the remains of a Hyundai excel that’s been sucked into the intake.
about the pic of 'CHOP YA' F6
NC1183 is offline   Reply With Quote Multi-Quote with this Post
Old 01-07-2008, 02:53 PM   #7
b2tf
b2tf's Avatar
Im not 100% but Ive heard of guys getting BA seats 'made" onto AU rails - got no idea how its done or what has to be changed. If you mess with the factory seat rails though you do require engineering certificate which is why its easier to modify the seats instead of the rails.
2024 F150 XLT
Old 01-07-2008, 02:54 PM   #8
sikford
THE Fairmont Ghia 75th
sikford's Avatar
its a weld job for the ba seats, not an impossible task if your not a bad welder, mate did it in his au but the welds were shockin,lol
Current Ride : AUII Fairmont Ghia : 75th Anniversary Limited Edition
Current Mods-HD Built Gearbox+(Mirror Polished, Modified Valve Body), 2500rpm Hi-Stall Convertor(TCE Custom Built), BIG Trans Cooler, Braided Lines/Speedflow Fittings, 2.5" Exhaust, Custom CAI, Detailed UnderCarriage, Custom SQ Stereo Install.
My Ride
My Build Thread
sikford is offline   Reply With Quote Multi-Quote with this Post
Old 01-07-2008, 02:59 PM   #9
NC1183
NC1183's Avatar
Do u think u could get photo's on the mods to the rails so we could have a look at how they need to be modified
Nathan
The SP
The old ute (sold)
Build Thread
Old 01-07-2008, 10:02 PM   #10
Mont5.0
Mont5.0's Avatar
so the fronts are easy? its only the rear thats hard?
Old 01-07-2008, 10:36 PM   #11
private9
www.TUFFCARPARTS.com
private9's Avatar
Bomber did BA XR seats in his AU XR6. As has already been said, it required welding.
Old 02-07-2008, 06:50 PM   #12
Uncle_Ken
Next upgraded Mk1 Leopard
Uncle_Ken's Avatar
Yeah the wreckers out at Macarthur Parts Plus in NSW said no swap, nothing lines up re bolts etc.
I'd be worried insurance if you had BA's welded onto AU rails.
UK
Old 02-07-2008, 08:00 PM   #13
blackers10
blackers10's Avatar
you only need an engineers certificate to say its done properly which then makes it fine for insurance purposes.
and the cert is only required IF you modify or swap out the standard rails
if your new seat bolts onto the old rails then your sweet to go
