Old 22-06-2008, 06:33 PM   #1
V8falcons
V8falcons's Avatar
Default possible auto dramas
Gday fellas,this is mostly related to my auto trans but I want to pick the owners brains of AUs to get a better,AU only related answer so I wil post this here in the AU section before the transmission forum.
Ive been spending too much time on the AU sr wagon lately for my liking,with trying to fix the timming case oil leak(still not completely sorted),replaced the radiator and fitted an external trans cooler.
Now the trans seems to not be changing into top gear or overdrive on the expressway or from 80ks and it will rev at around 200-400 rpm higher( or About 2400rpm at 110ks) than our au ghia will at the same speed.
Since ive done the external tran cooler I have noticed this but cant be certain,my concern is (or one of them) would be the extrenal cooler size I fitted which now bypasses the new (manual) radiator totally.
I told the guy at the spares shop this trans will now be reliant souly on the new external cooler and he has suggested I choose this unit which,I think may be too small for the job.Its about 400 x 200 x 25mm(any one know the capacity of the radiator internal trans cooler for an AU).
After the cooler was fitted,I topped up the oil in the box but has since not changed into D-Drive from reverse a few times now for 5-10sec and no drive.
The next concern is,do the gear selector solinoids require replacing on AU box's after 250ish ks or is it worth going down the low k box route instead???
And can the higher revs(gear selection) be related to the TPS sensor as it may have been moved when LPG was recently installed????????
Any help would be appreciated,Im getting close to just considering now buying both a low Ks eng/trans and replacing the lot due to it having done 250ks now?????? Sorry for the long post : :
T2 TE50 no:154 Narooma blue
AU2 XR8 ute
XR4 fiesta
V8falcons is offline   Reply With Quote Multi-Quote with this Post
Old 22-06-2008, 07:24 PM   #2
Stav
Smile
Stav's Avatar
Your spare parts man has given you a tiny cooler. He has not done you any favours. Get the biggest tranny cooler money can buy.
From the sounds of the car not selecting drive from reverse it sounds like low oil.Recheck it soon. If you have done 250,000 kays on one box then you have a miracle on your hands. Recheck the oil my mate..Im not the best at finding problems but at least I am trying.
Old 22-06-2008, 08:33 PM   #3
GK
Walking with God
GK's Avatar
How much oil does the new cooler and lines take to fill? That's the amount of fluid needed to be added.
I'm not a mechnic, but low fluid, even slightly low can cause all sorts of gremlins. I had my box fully flushed (lines etc) and I had the box slipping and doing a few odd things.
I took it back and it needed less than 750mls of oil and it came back to me, smooth and reliable as before.
Hope that helps.
GK
Now gone!
On LPG
Want a Full Life? John 10:10
Old 23-06-2008, 07:19 PM   #4
V8falcons
V8falcons's Avatar
yeh,thanks guys,I filled the trans cooler before I fitted it,then I topped up the box,but its still playing up,Im taking this small trans cooler back thursday and going for the biggest one they have ,top up the oil and see how it goes,I got more prices for low k engine and box's today $950 with less than 80ks 2002 au3.
So id feel more inclined to do repairs that arnt going to be a waste on a newer drive train.
See what happens.
Regards
AU2 XR8 ute
XR4 fiesta
Old 26-06-2008, 11:36 AM   #5
V8falcons
V8falcons's Avatar
Ok,got the new big trans cooler,topped up the oil and seems to have solved the problem ,it was the torque converter locking up,not enough oil.Thanks for your help guys.
Regards
David
AU2 XR8 ute
XR4 fiesta
