Old 09-06-2008, 01:19 PM   #1
Tles
Default Lincoln MKS (AWD/FWD) drive impression, 3.7V6
Autoblog drove the new Lincoln MKS which features the 3.7 Duratec V6 with 6spdAuto and is based on the Taurus Fwd but in this instance is Awd. Just a drive impression not a full evaluation but interesting I think. Similar size vehicle to the Falcon and drivetrain (exc. platform RWD) as what is to come. There is already a big order bank for this model - shows how well Falcon would have worked in the US if LHD program had continued.
First Drive [w/VIDEO]: 2009 Lincoln MKS
Posted Jun 6th 2008 12:00PM by Sam Abuelsamid
Filed under: Sedans/Saloons, Lincoln, Driving
Every year, carmakers collectively trot out dozens of new concept vehicles at auto shows around the world. Some fraction of those end up making their way to production lines and onto the streets. Most of the exciting design ideas, however, get heavily watered down in the process of going from auto show stand to showroom. One notable exception is the new Lincoln MKS. When the original MKS concept turned up in 2006, it was basically a slightly fancied up version of the then-new Ford Five Hundred, and it was not warmly received.
In a pleasant change of direction, Ford took the lukewarm reception for the concept to heart and by the time the production version of the MKS appeared at the LA Auto Show last November, it had been transformed. Unlike the "so what" appearance of the concept, the production model elicited much stronger opinions. Some hated it, others loved it. Regardless of how you feel about the new look, it is now a fact of life. The MKS began emerging from Ford's Chicago assembly plant a few weeks ago and Ford invited us down to Washington DC to sample it on the road. Read our driving impressions and check out a video of Peter Horbury's walk-around tour of the new 2009 Lincoln MKS after the jump.
Gallery: First Drive: 2009 Lincoln MKS
Photos Copyright ©2008 Sam Abuelsamid / Weblogs, Inc.
Through the course of 2006, as the production MKS was being refined in the Lincoln Design Studio, Gordon Platto and other designers were also working on the MKR concept that debuted at the 2007 Detroit Auto Show. The team had identified a list of design elements that would define Lincoln's new design language. The most obvious element was the split-wing grille that hearkens back to Lincolns of the '30s and '40s such as the Zephyr and Continental. At that point, it was already too late to change the main body panels of the MKS. However, the team was so pleased with what they had wrought on the MKR, they made the late decision to apply the new face of Lincoln to the MKS.
It was a wise move. On the road, the new MKS has far more presence than any production Lincoln in years, including the late lamented LS. The MKS used the Five Hundred/Taurus platform as a starting point, but a lot has changed under the skin. The suspension has been heavily revised in order to handle the increased power and torque, as well as manage the motion of larger wheels and tires. The MKS has 18-inch wheels as standard equipment with 19- and 20-inch combinations available as options.
The basic Macpherson strut layout of the Taurus has been retained but the geometry has been modified to help minimize the effects of pushing 273 horsepower and 270 pound-feet of torque through the front wheels. The new geometry actually adds some anti-lift capability, as well. This works by using the reactive forces in the front end structure of the car during acceleration to help resist the tendency of the front end to lift up. The componentry that manages the motions of the rear wheels is more significantly changed. While the multi-link rear suspension still has an upper control arm along with lower trailing, toe and lateral links, all the pieces are new.
The mounting of the rear dampers in the MKS has also been moved further outboard toward the wheels. Moving the dampers closer to the wheels allows for greater travel, thus improving their effectiveness. The extra travel allows greater latitude for the engineers to tune the damping behavior for the optimum balance between comfort and handling. All of this helps maintain the ride quality that luxury car buyers expect while providing better handling and road holding with the 20-inch wheel/tire combo. On the road all of this works remarkably well.
We started off our first drive in the MKS from an Alexandria, VA Lincoln dealership in an all-wheel-drive model. The car was finished in a color dubbed Tuxedo Black. Unlike a typical metallic finish that is impregnated with metal particles, the Tuxedo finish uses tiny glass beads. When the light hits it right, it truly shimmers, much like the mystic paint that was used on mid-90s Mustang Cobras. We were able to see one car in light that was similar to what you get during the magic hour later in the day or early morning, and it truly looked spectacular and expensive.
Our car was fitted with the 20-inch wheel and tire package that uses 245/45R20 Michelin tires. At launch, all MKS sedans will be fitted with the new 3.7L version of the V6 used in other large Fords, Lincolns and the Mercury Sable. The 3.7L is rated for running on regular unleaded, which gives it an output of 273 hp and 270 lb-ft of torque. If you choose to drop the extra cash on premium petrol, you'll be rewarded with an extra 2 hp and 6 lb-ft, a difference you're unlikely to notice on the road. Around March or April of 2009, the new EcoBoost V6 will become available in the MKS that will provide 340 hp and an equal number of lb-ft of twist. Power gets sent primarily to the front wheels via the same 6F50 six-speed automatic transmission used with the 3.5L V6 in other applications. The only difference in the MKS is the final drive ratio in the all-wheel-drive model.
The front-wheel-drive versions all get a 3.16:1 final drive, while the AWD Taurus uses a 2.77:1 ratio. The AWD MKS we drove had a shorter 3.39:1 ratio. Up to 25 percent of the drive torque goes to the rear axle as determined by an electronically controlled clutch pack. The rear torque is limited to keep the size of the drive shaft and rear axle down. Unlike some similar systems that rely on front wheel slip to trigger torque transfer, this one factors in throttle position and acceleration to send tractive effort rearward before the front wheels slip.
The ride route took us through a mix of urban, highway and rural driving from Alexandria to the Prince Michel Winery in Leon, VA. After a break at the winery, we continued on a loop that eventually brought us back to Georgetown in DC. One aspect of the MKS that was immediately apparent was the sense of quiet in the cabin. The side glass is laminated with two layers of glass sandwiching a layer of plastic. Even with serenity, it wasn't completely isolated the way that some Lexus models have been over the years. Just enough of the outside gets through to remind you that it's still there without intruding on the sense of calm. Driving along in urban traffic alongside a noisy truck, the noise was almost completely blocked out.
That calm isn't disturbed by the action at the road either. Even with low profile rubber on those big wheels, occupants don't take a beating. On some rough pavement that included sudden changes in road elevation and construction zones, the new suspension setup proved its worth. The changes in the rear allowed the engineers to tune in more rebound control over gaps and potholes. Essentially, they found that having the wheel resist the urge to follow the pavement downward to quickly and almost float over the gap provided a much smoother ride. At the same time, the jounce control allows even the heavy 20-inch rims to move up and out of the bumps. The real test will of course come in a couple of weeks when the MKS arrives in our Michigan-based Autoblog Garage for a full review. Then we'll find out how well this all really works.
Other aspects of the car's dynamics also appeared to work quite well. Some of the roads on our route were of the type best left to serious sports cars, but the big Lincoln remained thoroughly composed even where the pavement was still damp from storms that had passed a short time earlier. The MKS, at least with the current engine, doesn't really qualify as a sports sedan and Lincoln identifies its chief competitors as the Cadillac STS and Lexus GS. The MKS certainly felt on a par with the Cadillac, although we haven't tried the GS lately. Through the curves, at around eight-tenths, the big black Lincoln didn't really exhibit any noticeable understeer and if the stability control did activate, it wasn't at all intrusive.
Speaking of those storms, we had our drive on Wednesday June 4 when a series of severe thunderstorms swept through the region and at least one tornado is thought to have touched down. As we were on the second leg of the route, we could see the storms in the distance so we brought up the weather map using the Sirius travel link on the nav system. Sure enough, it showed all the storms in the immediate area pretty much live. We managed to miss the brunt of the storms, but we did get into some scattered rain. I set the intermittent wipers on their lowest setting to try out the Rain-Sense system. Sure enough, as the volume of rain picked up, so too did the interval shorten and they eventually went into normal continuous mode. As the rain stopped, so did the wipers. No more dry wipers dragging across the windshield.
As we made our way down one debris strewn road, other Lincolns appeared heading the opposite direction flashing their lights at us. Apparently a tree was blocking the road ahead, so we swung around and decided that based on the conditions it might be wiser to just make a bee-line straight for D.C. and skip the rest of the route. The voice commands for the nav worked quite well until both my driving partner and I tried to give commands at the same time, which left it befuddled. At that point I let him enter the destination while I tried to avoid fallen trees.
Overall, the MKS proved to be a very capable cruiser that didn't object at all to some back road thrashing. The only thing that might be considered a weakness is the engine. Hard acceleration drew quick but smooth kick-downs from the transmission followed by steady but not punch-you-in-the-back acceleration. It was certainly adequate, just not thrilling. Of course, in these times of high prices at the pump, that may not be such a bad thing. For those that want more, the EcoBoost is coming soon.
Peter Horbury gives a walk-around tour of the Lincoln MKS
Tles is offline   Reply With Quote Multi-Quote with this Post
Old 09-06-2008, 01:32 PM   #2
arlester
I know this mayjust be me but in between the A and C pillars looks 100% Falcon.
Maybe signs that Ford Aus is getting more recognised
arlester is offline   Reply With Quote Multi-Quote with this Post
Old 09-06-2008, 01:45 PM   #3
Paxton
Cobblers!
Paxton's Avatar
I see it too, and I like what I see.
Lincoln might be a shining light inside the Ford stable. If they keep up with the In Your Face designs, I think they have a good future in front of them. Especially in the export market.
Ego BFII Ghia
Titanium Silver E53 X5 4.4i
Gunmetal EF XR6. Now retired from active duty.
Roses are red. Violets are blue. OS X rocks. Homage to you.
Paxton is offline   Reply With Quote Multi-Quote with this Post
Old 09-06-2008, 06:41 PM   #4
Yellow_Festiva
Where to next??
Yellow_Festiva's Avatar
That 3.7 ecoboost mill sounds the goods! 255ish kw.. perhaps that will be used for higher spec Falcons after the I6???
Old 09-06-2008, 06:46 PM   #5
89.SVO
89.SVO's Avatar
it is. the new V6 is from the same family as the Lincoln and new Mazda CX9. i know this because i work at Mazda
89.SVO is offline   Reply With Quote Multi-Quote with this Post
Old 09-06-2008, 10:11 PM   #6
alecrain
'03 BA XT
alecrain's Avatar
Cool EcoBoost
The all new FORD Falcon XR6EcoBoost -sounds so sexy doesn't it?
Melbourne family photographer -Discount for AFF members (PM me first) :
Beautiful Photography Blog
2003 BA XT
IMPCO SVI - TYPHOON CAI +XR6T snorkel - K&N Panel Filter - DBA Slotties - Tint
1998 Toyota Landcruiser Prado
www.bseries.com.au/alecrain
People that drive slower than ME are BAD DRIVERS,
People that drive faster are IDIOTS
alecrain is offline   Reply With Quote Multi-Quote with this Post
Old 09-06-2008, 10:13 PM   #7
Paxton
Cobblers!
Paxton's Avatar
I prefer TwinBoost (a combination of the two previous names - TwinForce and EcoBoost).
EB S-pac - the same family of engines, yes. The same engine, no. Falcon is expected to get Direct Injection, among other things, which will help fuel economy and power. The CX-9's engine is made in Japan, also.
Ego BFII Ghia
Old 09-06-2008, 10:17 PM   #8
XplosiveR6
Viper FG XR6 Turbo
XplosiveR6's Avatar
Thats 203kw and 266nm's, not too bad. i wonder if the extra power will make up for the loss of torque over the I6 though.
XplosiveR6 is offline   Reply With Quote Multi-Quote with this Post
Old 09-06-2008, 10:21 PM   #9
Paxton
Cobblers!
Paxton's Avatar
366NM's, and that is in MPEFI Form. Wait until we see the Direct Injection numbers (which I am told are excellent) before passing judgement. We aren't going to be behind Holden, I can safely say.
Ego BFII Ghia
Old 10-06-2008, 07:24 AM   #10
89.SVO
89.SVO's Avatar
oh okay. now the CX-9 motor pulls that 2t very well and easily so it'll pull a Falcon very well
Old 10-06-2008, 08:35 AM   #11
Swordsman88
Getting it done.....
Swordsman88's Avatar
400+nm hey Paxton?? Is this torque number (366) on that weak stuff they use in the states (isn't it like 87 RON or something?). I do hope Ford is able to keep some of the I6s legendary low down pull...maybe not as much but make it decent so it can haul its own weight up small hills without going down 3 gears (aurion anyone?).
As for Holden, they can forget it. Their 'its coming soon....' DI HFV6 from cadilac would have a hard time taking the old I6 down....hasn't a hope against the new Duratec. Ford should keep its large torque advantage easilly.
Swordsman88 is offline   Reply With Quote Multi-Quote with this Post
Old 10-06-2008, 09:45 AM   #12
Fev
Fev's Avatar
ooo i really like that car, for once a high rear end looks good!
1992 EBII Fairmont Ghia 4.0l <---Click for the Gallery!
Insta@mooneye_ghia
White on bright red smoothies with thick whitewalls. Cruising around to some rockabilly
Fev is offline   Reply With Quote Multi-Quote with this Post
Old 10-06-2008, 04:54 PM   #13
Rodp
Regular Schmuck
Rodp's Avatar
Just like with everything else, their measurements are different to ours. Their 87 is equivalent to our 95, IIRC.
Old 10-06-2008, 05:11 PM   #14
antony101
best looking sedan i have seen in a while.
http://www.autoblog.com/2008/06/06/f...n-mks-w-video/
Check that mini bonnet buldge - lovely..
antony101 is offline   Reply With Quote Multi-Quote with this Post
Old 10-06-2008, 06:47 PM   #15
Yellow_Festiva
Where to next??
If the size of the yank car is close to the Falcon, why are we spending so many hundreds of millions of dollars to develop our own large car for such a captive market??
Makes no sense at all! Either Aus Ford make the Falcon to be sent over to the states as a mainstream model or US Ford send over their mainstream large car as a replacement for Falcon.
I think the US large cars and the Aus large cars are getting close to being on parr in terms of tastes in design...
Imagine, if we imported a new large car, based on the R/D done already for the Americans we could spend a fraction of the development costs for a new car, and hopefully pass on a greater profit to Ford as a whole??
Not again... smoke from the ears.. brain is thinking tooo much!
