Old 16-05-2008, 06:58 PM   #1
JMO
JMO's Avatar
Default Replacing Fuel Filter
There was a short guide on here somewhere that went through the process of changing the fuel filter. I've tried searching but can't find it.
If anyone knows the link or can give me a quick run down on what needs to be done, I'd really appreciate it
JMO is offline   Reply With Quote Multi-Quote with this Post
Old 16-05-2008, 07:12 PM   #2
GK
Walking with God
GK's Avatar
Is this it?
Changing Fuel Filter
http://www.fordforums.com.au/showpos...3&postcount=37
All the best with it,
GK
Now gone!
On LPG
Want a Full Life? John 10:10
Old 16-05-2008, 07:20 PM   #3
JMO
JMO's Avatar
Thats the one
I should have known you did the write up lol
While I've got your attention, how do you go about loosening the tensioner/fan belt. I was told to put a 3/8 ratchet in the square hole but I don't know which way (anti/clockwise) to turn as it seems to be on very tight.
Do you have any tips?
Old 16-05-2008, 07:36 PM   #4
mik
mik's Avatar
you have to push the ratchet handle towards the passenger side gaurd(or clockwise), you need to put a bit of muscle behind it, a small bit of pipe on the end of the ratchet or a jack handle will make it easier.
Old 16-05-2008, 07:53 PM   #5
JMO
JMO's Avatar
Cheers.
Thanks for the help guys.
Old 17-05-2008, 11:51 AM   #6
WoodysXR6
Wanting a sprint!
WoodysXR6's Avatar
I just changed my dads filter on his ute.
It was a straight forward swap, Just it had a 14mm nut instead of 15mm.
Is that how all series 1 models are?
Gk great doc cheers, Woody
On track for mint turbo falcon
WoodysXR6 is offline   Reply With Quote Multi-Quote with this Post
Old 17-05-2008, 09:06 PM   #7
bodes-sh
removing the belt sometimes helps if you pull on the top at the same time you are pushing the ratchet, i broke a cheapie ratchet by hanging off it too hard, then tried again by pulling another part of the belt and loosened straight away
Old 18-05-2008, 03:35 PM   #8
JMO
JMO's Avatar
I'm having trouble getting the black hose off. I've tried putting the screwdrivers down the side but nothing gives. Anyone whose done it can help?
EDIT: Don't worry. Just as I pretty much gave up on it for fear of breaking it. I got it off.
