Old 13-05-2008, 10:52 AM   #1
BillC
Default Throttle stays high for 1 second
Just bought a manual ute and when I got it the revs had about a two second delay when you take your foot off the accelerator. As in the revs stay put for a few seconds till it drops to idle. I took it to a mate of mine and he pointed out the power steering sensor was faulty and holding the revs high. After I replaced it it definately improved but it still had a slight delay. I guess about 1 second. My mate thought the computer might have to relearn but its been about 2 weeks now. Its not the throttle cable and I have cleaned out the thing (forgot the name at this moment) that controls the idle. I also swapped the TPS with a mates and its not that. Any ideas would be appreciated.
BillC is offline   Reply With Quote Multi-Quote with this Post
Old 13-05-2008, 10:53 AM   #2
BillC
It also idles quite well after the delay.
Old 13-05-2008, 10:58 AM   #3
honer
Back to N/A land
Mine AUIII XR8 does the same thing, however since I've only driven in like 40km in total over the last 6 months it hasn't really been an issue for me
None the less, I experienced the same thing.. But never troubleshooted (If it is even a problem -- dashpot delay increase to combat clunky gear changes ??)
honer is offline   Reply With Quote Multi-Quote with this Post
Old 13-05-2008, 12:23 PM   #4
75van
Van Mad
75van's Avatar
Is the aircon on? I noticed that mine does a similar thing when the aircon is on - holds the revs up a bit when changing gears...
The new wheels: 1975 Ford Escort panelvan. Build blog here.
75van is offline   Reply With Quote Multi-Quote with this Post
Old 13-05-2008, 12:39 PM   #5
BillC
Yes and no monkeysxr6. I have tried it either way and I still have the delay. One thing I did try was disconnecting the TPS and it seems to fix the problem. But my mate tells me that its just telling the computer that the throttle is still at idle. Like I said though I did swap the TPS with a mates and it still does the same thing. I am guessing its another sensor problem. But which one ? What would be the consequences if I put a plate between the thing that automatically adjusts the idle so that it becomes ineffective and then adjust the idle with the stop screw ?
Old 13-05-2008, 12:52 PM   #6
BillC
To fault find the power steering sensor my mate started the car and got me to move the steering wheel. He said the revs should increase slightly. I did this and the revs did not move. He them disconnected the sensor and put a short accross the terminals and the revs improved straight away. With the aircon I definately notice a change in revs between aircon cycles so I am guessing the aircon sensor is OK. What else is supposed to control the idle that I can check ?
Old 13-05-2008, 12:58 PM   #7
JC
JC's Avatar
The ISC valve. Cleaning it if it's a little buggered is only a short term stop gap. It may actually be bad enough to need replacing.
Ford Performance Club ACT
Old 13-05-2008, 02:36 PM   #8
BillC
JC, where is the ISC valve and what does it do ?
Old 13-05-2008, 05:22 PM   #9
GK
Walking with God
GK's Avatar
It controls the idle speed.
Here's how to find and clean it.
Cleaning ISC Valve
http://www.fordforums.com.au/showpos...9&postcount=43
Cheers,
GK
Now gone!
On LPG
Want a Full Life? John 10:10
Old 13-05-2008, 06:44 PM   #10
sly
Sly like a G6
sly's Avatar
"ISC" is what JC calls the IAC... you know...
Sleeper, anyone?
Old 14-05-2008, 01:38 AM   #11
JC
JC's Avatar
Thanks Sly.
Ford know it as the Idle Air Control Valve, I guess colloquially it is known as he Idle Speed Control valve. The rest...I think you know already.
Old 14-05-2008, 09:03 AM   #12
BillC
I have actually cleaned the ISC or the IAC but noticed little difference (thats the thing I couldnt name in my first post). I will swap it with my mates and see if that makes a difference. Thanks guys and girls.
Old 14-05-2008, 11:15 AM   #13
brad`
The Monty
brad`'s Avatar
my mates XR6 EL does the same thing the revs stay up for like a seconds then drop, i just ashumed it was an XR thing...
brad` is offline   Reply With Quote Multi-Quote with this Post
