Old 11-05-2008, 05:22 PM   #1
RG
Back to Le Frenchy
RG's Avatar
Default IRS shock mount Q
Real quick question, I did a search and couldn't find the answer.
The centre nut at the top of the mount, is that supposed to be tight? I am pretty sure it is but I just found mine to be loose.
Cheers.
Old 11-05-2008, 05:27 PM   #2
FTe342
FTe342's Avatar
Yes mate, supposed to be tight. Put an allen key in the head of the shaft and tighten the nut OR just use an air gun if its out of the car
T3 TL50 #147 Silhouette Auto ESS - Brembos - Last of 3 in T3 spec, only AUIII TL50 ever built -14.2 sec @ 98mph bog stock. Only customer ordered T3 TL50 built, only LWB sedan plated AUIII and the last performance enhanced LWB sedan built by Ford Aust.
AUII Fairlane Ghia Sportsman 5.0L in Blue Pearl
OWN THE ROAD
FTe342 is offline   Reply With Quote Multi-Quote with this Post
Old 11-05-2008, 05:57 PM   #3
RG
Back to Le Frenchy
RG's Avatar
Cheers Shayne. Is the head of the shaft under the car or accessible from the boot?
Old 11-05-2008, 11:49 PM   #4
RG
Back to Le Frenchy
RG's Avatar
Sorted. With help from Shaynet and a little of my own ingenuity I think I have fixed it. Shayne informed me that the mounts that I have used (Ford ones) have a slightly different design to them than the original units causing the securing bolt to not be able to grab the thread properly as the new mount allows the shaft of the strut to come through further. With the car still on the ground I was able to get a shifter on to the shaft while getting a ring spanner onto the nut to undo it. After that is was simply a case of using 3 std thickness washers to space the bolt up a bit so I could tighten it all up properly. Problem solved.
Old 12-05-2008, 11:22 AM   #5
FTe342
FTe342's Avatar
Yes, sorry for the bum steer. The Koni's on the T Series have the allen key hole in the end of the shaft but the Munroes have the flat end
OWN THE ROAD
