Old 01-05-2008, 07:49 PM   #1
halo
Default good cheap exhaust in syd?
rang up a few shops for quotes on putting my lukey extraqctors into the EA.. $200 was the cheapest i was offered. Now these aren't the long pacemaker ones, they are fairly short and the only reason i dont put them in myself is because i cannot weld and i need a 3" tube to connect them to the cat
how much should i be paying? i think 200 is far too much if the cat doesn't have to be relocated and the exhaust chopped and welded. anyone know where i should go? thanks
halo is offline   Reply With Quote Multi-Quote with this Post
Old 02-05-2008, 06:03 AM   #2
The Yeti
The Yeti's Avatar
I would think $200 is great value for money 2 hours and a bit of messing arround I wouldnt do it for that as a back yard job for that.
Pariahs C.C.
What could possibly go wrong
I post images with postimg.cc (so I don’t forget)
The Yeti is offline   Reply With Quote Multi-Quote with this Post
Old 02-05-2008, 11:36 AM   #3
ebxr8240
Performance moderator
ebxr8240's Avatar
If your that desperate to save money and good on you...
Fit extractors yourself with cat welded on. Make sure you have the correct pipe size that fits over both ends to join them with clamps, if you want, you can then drive in to exhaust shop to get them welded..
I think Windsor exhaust is an o/k shop out your way ???
Daily driver GTE FG..
