Old 28-04-2008, 12:49 PM   #1
montyv8
Turbo Dinosaur FTMFW
montyv8's Avatar
Default drag radials tyre pressure?
thought i'd start a thread here after the conversation in the clevo forum about tyre pressures.
I'll be running a pair of Mickey T et street radials (275/50/15) on my coupe at the Aff meet this weekend, I think a few others will be running the same tyres.
I'm curious to know peoples opinions on what tyre pressure I should run, any suggestions on warming them up, such as just a quick small burnout, etc, and anything else that could be useful to this first-timer
I have no idea how much prep work is done to the track at heathcote, maybe someone else can help with that info?
Thanks.
1973 XB Fairmont Coupe, turbo EFI SBF
8.23@168MPH
montyv8 is offline   Reply With Quote Multi-Quote with this Post
Old 28-04-2008, 02:57 PM   #2
gregaust
13 PSI ,same size tyre and didn't need a real big skid though willowbank is pretty well prepped .
Old 28-04-2008, 04:38 PM   #3
Falcon Coupe
Clevo Mafia Inc.
Falcon Coupe's Avatar
Chairman's Award: Chairman's Award - Issue reason: The exceptional contribution made to AFF over an extended period of time. Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Your tireless efforts behind the scenes in keeping AFF the place it is.
Greg is that cold or warm pressure ?
Falcon Coupe is offline   Reply With Quote Multi-Quote with this Post
Old 28-04-2008, 05:17 PM   #4
naughts
Hmmmmm Mulberry....
naughts's Avatar
I run mine at 18-20 psi
naughts is offline   Reply With Quote Multi-Quote with this Post
Old 28-04-2008, 05:38 PM   #5
nugget378
Weezland
nugget378's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: Always willing to impart knowledge in the technical areas.
12psi cold worked for me with 235/15's.
They have a stiffer sidewall than a full slick.
nugget378 is offline   Reply With Quote Multi-Quote with this Post
Old 28-04-2008, 06:27 PM   #6
XDean
XDean's Avatar
Guys, straight from the MT tech bulletin,
Proper use of Mickey Thompson ET Street Radial
Inflation Pressures
On the racetrack DO NOT use starting pressures below 11 psi.
Recommend pressures for:
P295 and larger sizes: 11-14 psi
P275 and smaller sizes: 12-16 psi
On the highway we recommend running 75% of the max psi as notes on the sidewall of the tire.
Burnouts
The tread compound used in the ET Street Radials is designed to heat quickly and does not require a heavy burnout. Continue the burnout until the engine starts to pull down. We do not recommend a dry hop after the burnout.
Bead/Wheel Slippage
Some bead/wheel slippage may result during the course of a 1/4 mile (or 1/8 mile) drag race. This is normal.
Of course this is just the recommended parameters because every car/combo will be different but it is a good place to start.
____________________________________________
Cheers,
XDean is offline   Reply With Quote Multi-Quote with this Post
Old 28-04-2008, 06:35 PM   #7
HEMI POWER
N/A BOSS 390+
HEMI POWER's Avatar
Thats pretty spot on,i would run that the 1st time then go down from there.
HEMI POWER is offline   Reply With Quote Multi-Quote with this Post
Old 28-04-2008, 09:08 PM   #8
gregaust
13psi was warm .. Was on a 3200lb car running low 10's .
Old 28-04-2008, 09:29 PM   #9
TruBlu351
3 Pedals R Better Than 2
TruBlu351's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: Has given endless help in the cleveland section over the years. Knows his stuff and happily tests on the track and gives no fuss results.
Originally Posted by XDean
Burnouts
: thatīs why Tiapan kept blowing them off the line!! Heīs the burnout king ;)
XE Falcon - Under Construction
434 E85 Lawn Dart underway
TruBlu351 is offline   Reply With Quote Multi-Quote with this Post
Old 03-05-2008, 07:45 PM   #10
Crapi
I run mine at 14 psi, cold. 235/60-15 et street radial.
Crapi is offline   Reply With Quote Multi-Quote with this Post
Old 04-05-2008, 08:35 AM   #11
CAMS290
trying to get a leg over
CAMS290's Avatar
12-16 psi and check them after every run.
They can creep up by a couple of psi after a run.
Cameron
CAMS290 is offline   Reply With Quote Multi-Quote with this Post
